After a few tries, I need to ask for help here. After a fresh installation of home assistant, I wanted to again integrate towards Google Home via Nabu casa. My problem is that Google Home does not list any devices and instead state:
“No devices were found in your Home Assistant Cloud by Nabu C…”
Any idea what I can try to get back my Google Home <-> Home Assistant integration? all ideas appreciated!
What I have done:
- Controlled that the entities are exposed in the cloud configuration"
- Resynced entities via the cloud configuration view
- Logged/logged in into Nabu Casa
- Stopped/started Google Assistant service via the interface
- Tried to add cloud: in yaml
Logs are hard to make out but I get some errors that maybe can be related:
Error reporting state - 5: Requested entity was not found.
Logger: homeassistant.components.cloud.google_config
Source: components/cloud/google_config.py:169
Integration: Home Assistant Cloud (documentation, issues)
First occurred: 12:02:16 (1 occurrences)
Last logged: 12:02:16
Error serializing binary_sensor.groventre
Logger: homeassistant.components.google_assistant.smart_home
Source: helpers/network.py:116
Integration: Google Assistant (documentation, issues)
First occurred: 12:01:16 (93 occurrences)
Last logged: 12:01:37
- Error serializing binary_sensor.groventre
- Error serializing binary_sensor.sidodorr_garage
- Error serializing binary_sensor.balkongdorr_overvaning
- Error serializing sensor.garage_temperature
- Error serializing sensor.vardagsrum_temperature
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/components/google_assistant/helpers.py”, line 510, in sync_serialize “baseUrl”: get_url(self.hass, prefer_external=True), File “/usr/src/homeassistant/homeassistant/helpers/network.py”, line 116, in get_url raise NoURLAvailableError homeassistant.helpers.network.NoURLAvailableError
