Trying to back up the system before attempting to upgrade. But when I try to run a backup I get this error:
Unknown error, see supervisor logs
In the logs I have the following details:
Error 1
Logger: homeassistant.components.hassio.handler
Source: components/hassio/handler.py:213
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 10:07:22 AM (2 occurrences)
Last logged: 10:07:37 AM
Source: components/hassio/websocket_api.py:109
Failed to to call /snapshots/reload -
Failed to to call /snapshots/new/full -
Further, when I attempt to upload an existing backup. I get this:
404 Not Found
I have plenty of storage space available. Any ideas?
I have the same issue on a RPi4 - but not on a Proxmox VM version of the same system.
I believe the backups are still being made, but the browser times out. Certainly when I look in the backup directory, it is still growing, and eventually it appears in the list of backups.
Interestingly, in looking for this issue I found a tmp directory under the backup folder that has 10s of GB of files, which is why my RPi version had filled the disk! Now it has been cleared out, backups have dropped from 4GB to 500MB and things run much easier, but the backups still time out.
Yes they’re still being created into the new folder name, but you can’t access them through ha. They can’t be restored if you can’t get to them. So they’re as useful as in they didn’t exist.
