After sending a few service calls to climate.set_temperature I’m getting an error in my HA logs.
Here’s the error:
Log Details (ERROR)
Error doing job: Task exception was never retrieved
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/service.py”, line 226, in _handle_service_platform_call
await func(entity, data)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/climate/init.py”, line 572, in async_service_temperature_set
await entity.async_set_temperature(**kwargs)
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/climate/nest.py”, line 219, in set_temperature
self.device.target = temp
File “/usr/local/lib/python3.6/site-packages/nest/nest.py”, line 578, in target
self._set(‘devices/thermostats’, data)
File “/usr/local/lib/python3.6/site-packages/nest/nest.py”, line 206, in _set
response = self._nest_api._put(path=path, data=data)
File “/usr/local/lib/python3.6/site-packages/nest/nest.py”, line 1865, in _put
return self._request(‘PUT’, path, data=data)
File “/usr/local/lib/python3.6/site-packages/nest/nest.py”, line 1853, in _request
default_wait=5)
File “/usr/local/lib/python3.6/site-packages/nest/nest.py”, line 1696, in _handle_ratelimit
retry_after = response.headers[‘Retry-After’]
File “/usr/local/lib/python3.6/site-packages/requests/structures.py”, line 52, in getitem
return self._store[key.lower()][1]
KeyError: ‘retry-after’
This basically bricks my Nest thermostat within HA until I restart HA. Physical Nest still works.
After a few minutes the log updates with:
Log Details (WARNING)
Haven’t received data from Nest in 5 mintues
This has happened both through testing a script that increments the temperature setpoint and within the more-info dialogue when I click on the climate entity. Happens after changing the temperature about 5 times in a row. And has happened after multiple restarts. Since it is also within the climate component I believe I can rule out my script but I’ll post it here anyways.
‘temperature_up’:
alias: Temperature Up
sequence:
- service: climate.set_temperature
data_template:
entity_id: climate.family_room
temperature: “{{ states.climate.family_room.attributes.temperature + 0.5 }}”
Using latest version of HA (82.0) and 3rd Gen Nest thermostat.
