I’ve had the Hive thermostat integration working for some time without problems, however, I now receive the following errors when I boot Home Assistant:
2022-07-21 11:14:01 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hive which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-07-21 11:15:33 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] for hive
File "/config/custom_components/hive/__init__.py", line 89, in async_setup_entry
devices = await hive.session.startSession(hive_config)
File "/usr/local/lib/python3.10/site-packages/apyhiveapi/session.py", line 494, in startSession
File "/usr/local/lib/python3.10/site-packages/apyhiveapi/session.py", line 417, in getDevices
await self.hiveRefreshTokens()
File "/usr/local/lib/python3.10/site-packages/apyhiveapi/session.py", line 304, in hiveRefreshTokens
File "/usr/local/lib/python3.10/site-packages/apyhiveapi/api/hive_auth_async.py", line 548, in refresh_token
I haven’t had the need to use the integration for a little while, and I’ve also recently changed my Broadband supplier with associated different router so IP address change for the Hive Hub.
However, I can log in to my Hive account from a web browser.
I’ve removed the Hive integration completely, then reinstalled it, adding my username and password during the installation, but still get the above errors.
Any ideas how to fix this?
