I was having issues with my nest configuration not updating correctly with updating with lovelace entity updates, so i wanted to reconnect the nest to my home assistant.
I saw under integrations that it is an option so i wen to configuration.yaml and commented out the nest section. reboot hass and it was still saying it is configured. i than tried to remove the lines completey from configuration.yaml and reboot the host machine.
Nothing i tried has worked, it still is reporting the data from the entities added by nest.
This is is also occuring when i try removing zwave, as i was trying to add it via the intergrations section as well.
Please let me know if i’m doing something wrong!
Instance Details:
HOST: Debian 9 (Running in VMWare Esxi 6.5)
Home Assistant Version: 0.81.6
Hass.io Supervisor Version: 139
