Trying to set up smtp to be able to send mails to myself through HA.
config is as follows (with sensitive data changed to example.com):
- name: summary_mail
platform: smtp
server: smtp.example.com
port: 587
timeout: 15
sender: [email protected]
encryption: tls
username: my_smtp_username
password: !secret summary_mail_password
recipient:
- [email protected]
sender_name: SkyHome Summary
Log is as follows:
File "/usr/src/homeassistant/homeassistant/components/notify/__init__.py", line 78, in async_setup_platform
platform.get_service, hass, p_config, discovery_info
File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 84, in get_service
if mail_service.connection_is_valid():
File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 138, in connection_is_valid
server = self.connect()
File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 122, in connect
mail = smtplib.SMTP_SSL(self._server, self._port, timeout=self._timeout)
File "/usr/local/lib/python3.7/smtplib.py", line 1031, in __init__
source_address)
File "/usr/local/lib/python3.7/smtplib.py", line 251, in __init__
(code, msg) = self.connect(host, port)
File "/usr/local/lib/python3.7/smtplib.py", line 336, in connect
self.sock = self._get_socket(host, port, self.timeout)
File "/usr/local/lib/python3.7/smtplib.py", line 1039, in _get_socket
server_hostname=self._host)
File "/usr/local/lib/python3.7/ssl.py", line 423, in wrap_socket
session=session
File "/usr/local/lib/python3.7/ssl.py", line 870, in _create
self.do_handshake()
File "/usr/local/lib/python3.7/ssl.py", line 1139, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1076)
Any ideas what could be the cause of this? I have the same smtp account imported in my gmail and there it works, so credentials, server etc should be good to go.
