I’m running HassOS 1.11 and Home Assistant 0.78.3. I’ve decided to update, but doing so from the WebUI gives an error in the log saying that the docker image can’t be fetched (404):
18-12-31 18:28:26 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.84.6 18-12-31 18:28:26 INFO (SyncWorker_5) [hassio.docker.interface] Update Docker 0.78.3 with homeassistant/raspberrypi3-homeassistant:0.84.6 18-12-31 18:28:26 INFO (SyncWorker_5) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.84.6. 18-12-31 18:28:38 ERROR (SyncWorker_5) [hassio.docker.interface] Can't install homeassistant/raspberrypi3-homeassistant:0.84.6 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi3-homeassistant:0.84.6: No such image: homeassistant/raspberrypi3-homeassistant:0.84.6"). 18-12-31 18:28:38 WARNING (MainThread) [hassio.homeassistant] Home Assistant is already running! 18-12-31 18:28:38 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.84.6
Running via ssh update on the host of the home assistant gives the error below:
➜ ~ hassio -d ho update
DEBUG [CmdHost]: action->'update', endpoint='update', serverOverride->'', GET->'false', options->'', rawjson->'false', filter->''
DEBUG [ExecCommand]: basepath->'host', endpoint->'update', serverOverride->'', get->'false', Options->'', Filter->'', RawJSON->'false'
DEBUG [GenerateURI]: basepath->'host', endpoint->'update', serverOverride->''
DEBUG [RestCall]: data->'http://hassio/host/update', GET->'false', payload->''
DEBUG [RestCall]: ResponseBody->'403: Forbidden'
Error decoding json invalid character ':' after top-level value: 403: Forbidden#➜ ~ hassio -d ha update
DEBUG [CmdHomeassistant]: action->'update', endpoint='update', serverOverride->'', GET->'false', options->'', rawjson->'false', filter->''
DEBUG [ExecCommand]: basepath->'homeassistant', endpoint->'update', serverOverride->'', get->'false', Options->'', Filter->'', RawJSON->'false'
DEBUG [GenerateURI]: basepath->'homeassistant', endpoint->'update', serverOverride->''
DEBUG [RestCall]: data->'http://hassio/homeassistant/update', GET->'false', payload->''
What do I need to do to stay up to date?
