I haven't used my Home Assistant for a while but can access it. Its a Raspberry Pi with Home Assistant OS 8.5 and Core 2022.8.6. I'm trying to update but get the following error message. "Error updating Home Assistan Core 'HomeAssistantCore.update' blocked from execution, system is not healthy - supervisor".
I have looked for a way to solve it but haven't found. Anyone else with similar experience.
You have a 4YO installation. If you have a PI3 it is likely a 32 bit version.
You appear to be running supervised which is deprecated as opposed to HAOS, so that can also be an issue.
I am not certain of your particular vintage, but if you have a backup function (you probably don't), then make a backup and start over. Otherwise just start over...
If it is a PI 3, get new hardware as well.
If you have to replace the hardware: Why NOT to buy a PI to run Home Assistant
See what's not healthy about your installation. You'll likely need to find the page yourself as the UI has changed a lot and I don't remember where it's located. But there's a system health page that will show you what's not healthy.
Hi there, thanks for your reply. Yes, I know its old :-(. I managed to backup so I guess you are right, probably just to start over. I thought maybe there could be a workaround so tried to find out. Thanks again!
Hi Petro, thanks. I'll try to find out. I found a command "ha resulution info". I notice several update_failed so I guess the best option from here is to start over with a new installation. Thanks a lot for your reply.
