I have got an error on almost everything I try to install on my new Home Assistant Green:
Logger: homeassistant.components.websocket_api.http.connection
Bron: components/websocket_api/commands.py:239
integratie: Home Assistant WebSocket API (documentatie, problemen)
Eerst voorgekomen: 16:19:49 (3 gebeurtenissen)
Laatst gelogd: 17:18:02
[281472424730304] Error updating Home Assistant Core ‘HomeAssistantCore.update’ blocked from execution, was unable to update plugin(s) audio and all plugins must be up to date first
[281472301359296] Error updating Home Assistant Core ‘HomeAssistantCore.update’ blocked from execution, was unable to update plugin(s) audio and all plugins must be up to date first
File “/usr/src/homeassistant/homeassistant/components/hassio/update.py”, line 304, in async_install
await async_update_core(self.hass, version=version, backup=backup)
File “/usr/src/homeassistant/homeassistant/components/hassio/handler.py”, line 59, in _wrapper
data = await funct(*argv, **kwargs)
File “/usr/src/homeassistant/homeassistant/components/hassio/handler.py”, line 256, in async_update_core
return await hassio.send_command(
File “/usr/src/homeassistant/homeassistant/components/hassio/handler.py”, line 593, in send_command
raise HassioAPIError(error.get(ATTR_MESSAGE))
homeassistant.components.hassio.handler.HassioAPIError: ‘HomeAssistantCore.update’ blocked from execution, was unable to update plugin(s) audio and all plugins must be up to date first
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 239, in handle_call_service
response = await hass.services.async_call(
File “/usr/src/homeassistant/homeassistant/core.py”, line 2543, in async_call
response_data = await coro
File “/usr/src/homeassistant/homeassistant/core.py”, line 2580, in _execute_service
return await target(service_call)
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 971, in entity_service_call
single_response = await _handle_entity_call(
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 1043, in _handle_entity_call
result = await task
File “/usr/src/homeassistant/homeassistant/components/update/init.py”, line 162, in async_install
await entity.async_install_with_progress(version, backup)
File “/usr/src/homeassistant/homeassistant/components/update/init.py”, line 466, in async_install_with_progress
await self.async_install(version, backup)
File “/usr/src/homeassistant/homeassistant/components/hassio/update.py”, line 306, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core ‘HomeAssistantCore.update’ blocked from execution, was unable to update plugin(s) audio and all plugins must be up to date first
