Stuck on a 2021.12.4 version… getting the below errors:
22-10-10 13:08:34 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2022.10.2
22-10-10 13:08:34 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:2021.12.4 to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.10.2
22-10-10 13:08:34 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.10.2.
22-10-10 13:10:34 ERROR (SyncWorker_0) [supervisor.docker.interface] Can’t install ghcr.io/home-assistant/qemux86-64-homeassistant:2022.10.2: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/qemux86-64-homeassistant:2022.10.2/json: Not Found (“no such image: ghcr.io/home-assistant/qemux86-64-homeassistant:2022.10.2: No such image: ghcr.io/home-assistant/qemux86-64-homeassistant:2022.10.2”)
22-10-10 13:10:34 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
Any help is appreciated.
-Brandon
