Hello everyone,
I have a problem since 2 months. I want to update my Home Assistant from 11.2 to 11.5 but I receive every time an error. I thought it will be solve in the next updates but I still have this issue.
Short information about my setup:
I have a mini pc from ThinkPad and run there Proxmox. It is directly connected with my router. I have the problem that my internet provider give me an DS-Lite connection so the access to my Home Assistant from web is over a Reversed Proxy and this is connected with an external rented Server via wireguard VPN. I don’t know if this is a problem. And another thing is that I run Adguard Home on that PC. I hope I don’t forget anything.
Here is the error text:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:240
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 16. Februar 2024 um 21:42:46 (2 occurrences)
Last logged: 18:19:46
- [140527728878528] Error updating Home Assistant Operating System: Can’t fetch OTA update from https://github.com/home-assistant/operating-system/releases/download/11.5/haos_ova-11.5.raucb: Cannot connect to host github.com:443 ssl:default [None]
- [140527323827136] Error updating Home Assistant Operating System: Can’t fetch OTA update from https://github.com/home-assistant/operating-system/releases/download/11.5/haos_ova-11.5.raucb: Cannot connect to host github.com:443 ssl:default [None]
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 240, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2279, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2316, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 892, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 962, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 161, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 465, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 214, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Operating System: Can't fetch OTA update from https://github.com/home-assistant/operating-system/releases/download/11.5/haos_ova-11.5.raucb: Cannot connect to host github.com:443 ssl:default [None]
I tried many things like new installation but there are some errors too like
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[17:09:30] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[17:09:30] INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
24-02-18 17:09:31 INFO (MainThread) [__main__] Initializing Supervisor setup
24-02-18 17:09:31 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
24-02-18 17:09:31 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: qemux86-64
24-02-18 17:09:31 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2024.01.1
24-02-18 17:09:31 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
24-02-18 17:09:31 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-02-18 17:09:31 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-18 17:09:31 INFO (MainThread) [__main__] Setting up Supervisor
24-02-18 17:09:35 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-02-18 17:09:35 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-02-18 17:09:35 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-02-18 17:09:35 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-02-18 17:09:35 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-02-18 17:09:35 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-02-18 17:09:35 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-02-18 17:09:35 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-02-18 17:09:35 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-02-18 17:09:35 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-02-18 17:09:35 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-02-18 17:09:35 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-18 17:09:35 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-18 17:09:35 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-02-18 17:09:35 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-18 17:09:35 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-02-18 18:09:39 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-02-18 18:09:39 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-02-18 18:09:42 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: [<AwesomeVersion CalVer '2023.11.0'>]
24-02-18 18:09:42 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.11.0
24-02-18 18:09:42 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-02-18 18:09:43 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2023.11.0 - 172.30.32.5
24-02-18 18:09:43 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: [<AwesomeVersion CalVer '2023.06.2'>]
24-02-18 18:09:43 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2
24-02-18 18:09:43 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-02-18 18:09:43 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3
24-02-18 18:09:43 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-02-18 18:09:43 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: [<AwesomeVersion CalVer '2023.12.0'>]
24-02-18 18:09:43 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0
24-02-18 18:09:43 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
24-02-18 18:09:43 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0 - 172.30.32.4
24-02-18 18:09:44 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
24-02-18 18:09:44 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
24-02-18 18:09:44 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
24-02-18 18:09:44 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
24-02-18 18:09:44 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: [<AwesomeVersion CalVer '2023.06.2'>]
24-02-18 18:09:44 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2
24-02-18 18:09:44 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
24-02-18 18:09:44 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host
24-02-18 18:09:44 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-02-18 18:09:44 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/qemux86-64-homeassistant
24-02-18 18:09:44 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/qemux86-64-homeassistant found.
24-02-18 18:09:44 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
24-02-18 18:09:44 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
24-02-18 18:09:44 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-02-18 18:09:44 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
24-02-18 18:09:45 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
24-02-18 18:09:45 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.0.rc1 / BootSlot A
24-02-18 18:09:45 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
24-02-18 18:09:45 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
24-02-18 18:09:45 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
24-02-18 18:11:56 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/esphome/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/esphome/home-assistant-addon /data/addons/git/5c53de3b
stderr: 'Cloning into '/data/addons/git/5c53de3b'...
fatal: unable to access 'https://github.com/esphome/home-assistant-addon/': Recv failure: Connection reset by peer
24-02-18 18:11:56 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/esphome/home-assistant-addon due to
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / 5c53de3b
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
24-02-18 18:11:56 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': Recv failure: Connection reset by peer
24-02-18 18:11:56 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/hassio-addons/repository due to
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / a0d7b954
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
24-02-18 18:11:56 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/home-assistant/addons /data/addons/core
stderr: 'Cloning into '/data/addons/core'...
fatal: unable to access 'https://github.com/home-assistant/addons/': Recv failure: Connection reset by peer
24-02-18 18:11:56 ERROR (MainThread) [supervisor.store] Can't retrieve data from core due to
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / core
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / core
24-02-18 18:11:56 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
24-02-18 18:11:56 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-02-18 18:11:56 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-02-18 18:11:56 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-02-18 18:11:56 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-18 18:11:56 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
24-02-18 18:11:56 INFO (MainThread) [__main__] Running Supervisor
24-02-18 18:11:56 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-02-18 18:11:56 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
24-02-18 18:11:56 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
24-02-18 18:11:56 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
24-02-18 18:11:56 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
24-02-18 18:11:56 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
24-02-18 18:11:56 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
24-02-18 18:11:56 INFO (MainThread) [supervisor.core] Supervisor is up and running
24-02-18 18:11:56 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
24-02-18 18:11:56 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2024.2.2
24-02-18 18:11:56 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2024.2.2.
24-02-18 18:11:56 INFO (MainThread) [supervisor.host.info] Updating local host information
24-02-18 18:11:56 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-02-18 18:11:56 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
24-02-18 18:11:56 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-18 18:11:56 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-18 18:11:57 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-18 18:11:57 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-02-18 18:12:06 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.2.2: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.2&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: TLS handshake timeout")
24-02-18 18:12:06 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-18 18:12:36 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2024.2.2
24-02-18 18:12:36 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2024.2.2.
24-02-18 18:12:46 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.2.2: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.2&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: TLS handshake timeout")
24-02-18 18:12:46 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
and now I am out of ideas.
I am thankful for every idea or someone knows maybe the problem.
Thanks for your help
