I have a problem, I can’t update my home assistant, i tried several times and i can’t, i tried a “default” configuration.yaml and the same any help?
19-11-07 11:20:25 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.101.2
19-11-07 11:20:25 INFO (SyncWorker_14) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.100.2 to homeassistant/raspberrypi3-homeassistant:0.101.2
19-11-07 11:20:25 INFO (SyncWorker_14) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.101.2.
19-11-07 11:24:09 INFO (MainThread) [hassio.hassos] Syncing configuration from USB with HassOS.
19-11-07 11:24:09 INFO (MainThread) [hassio.host.services] Restart local service hassos-config.service
19-11-07 11:24:09 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.RestartUnit on /org/freedesktop/systemd1
19-11-07 11:27:55 INFO (SyncWorker_14) [hassio.docker.interface] Stop homeassistant application
19-11-07 11:28:57 INFO (SyncWorker_14) [hassio.docker.interface] Clean homeassistant application
19-11-07 11:28:59 INFO (SyncWorker_4) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.101.2
19-11-07 11:29:29 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-11-07 11:30:45 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-11-07 11:30:55 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-11-07 11:32:05 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-11-07 11:35:23 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository
19-11-07 11:35:23 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/vkorn/hassio-addons repository
19-11-07 11:35:23 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
19-11-07 11:35:23 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-11-07 11:35:25 INFO (MainThread) [hassio.store] Load add-ons from store: 67 all - 1 new - 0 remove
19-11-07 11:42:10 WARNING (MainThread) [hassio.homeassistant] Don't wait anymore of Home Assistant startup!
19-11-07 11:42:10 CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback!
19-11-07 11:42:10 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.100.2
