trying to update from 0.91.4 to 0.93.2 getting following errors,
sorry but i have no idea what’s the problem …
I’m running homeassistant in a virtual environment.
Collecting cryptography==2.6.1 (from homeassistant)
Using cached https://files.pythonhosted.org/packages/07/ca/bc827c5e55918ad223d59d299fff92f3563476c3b00d0a9157d9c0217449/cryptography-2.6.1.tar.gz
Installing build dependencies … error
ERROR: Complete output from command /srv/homeassistant/bin/python3 /srv/homeassistant/lib/python3.5/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-j2_kqgp4/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple – ‘setuptools>=18.5’ wheel ‘cffi>=1.8,!=1.11.3; python_implementation != ‘"’"‘PyPy’"’"’’:
ERROR: Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple, https://www.piwheels.org/simple
Collecting setuptools>=18.5
Using cached https://files.pythonhosted.org/packages/ec/51/f45cea425fd5cb0b0380f5b0f048ebc1da5b417e48d304838c02d6288a1e/setuptools-41.0.1-py2.py3-none-any.whl
Collecting wheel
Using cached https://files.pythonhosted.org/packages/bb/10/44230dd6bf3563b8f227dbf344c908d412ad2ff48066476672f3a72e174e/wheel-0.33.4-py2.py3-none-any.whl
Collecting cffi!=1.11.3,>=1.8
Using cached https://files.pythonhosted.org/packages/93/1a/ab8c62b5838722f29f3daffcc8d4bd61844aa9b5f437341cc890ceee483b/cffi-1.12.3.tar.gz
Collecting pycparser (from cffi!=1.11.3,>=1.8)
Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.19-py2.py3-none-any.whl
Building wheels for collected packages: cffi
Building wheel for cffi (setup.py): started
Building wheel for cffi (setup.py): finished with status ‘error’
ERROR: Complete output from command /srv/homeassistant/bin/python3 -u -c ‘import setuptools, tokenize;file=’"’"’/tmp/pip-install-khjyxz8y/cffi/setup.py’"’"’;f=getattr(tokenize, ‘"’"‘open’"’"’, open)(file);code=f.read().replace(’"’"’\r\n’"’"’, ‘"’"’\n’"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ bdist_wheel -d /tmp/pip-wheel-p89nlrxa --python-tag cp35:
ERROR: Package libffi was not found in the pkg-config search path.
Perhaps you should add the directory containing libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing
libffi.pc’
No package ‘libffi’ found
libffi.pc’
Perhaps you should add the directory containing libffi.pc' to the PKG_CONFIG_PATH environment variable No package 'libffi' found running bdist_wheel running build running build_py creating build creating build/lib.linux-armv7l-3.5 creating build/lib.linux-armv7l-3.5/cffi copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/commontypes.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/cparser.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/api.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/model.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/error.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/lock.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/verifier.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/vengine_gen.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/pkgconfig.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/__init__.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/ffiplatform.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/recompiler.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-3.5/cffi copying cffi/_cffi_include.h -> build/lib.linux-armv7l-3.5/cffi copying cffi/parse_c_type.h -> build/lib.linux-armv7l-3.5/cffi copying cffi/_embedding.h -> build/lib.linux-armv7l-3.5/cffi copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-3.5/cffi running build_ext building '_cffi_backend' extension creating build/temp.linux-armv7l-3.5 creating build/temp.linux-armv7l-3.5/c arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fdebug-prefix-map=/build/python3.5-6waWnr/python3.5-3.5.3=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/ffi -I/usr/include/libffi -I/srv/homeassistant/include -I/usr/include/python3.5m -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.5/c/_cffi_backend.o c/_cffi_backend.c:15:17: fatal error: ffi.h: Datei oder Verzeichnis nicht gefunden #include <ffi.h> ^ compilation terminated. error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1 ---------------------------------------- ERROR: Failed building wheel for cffi Running setup.py clean for cffi Failed to build cffi Installing collected packages: setuptools, wheel, pycparser, cffi Running setup.py install for cffi: started Running setup.py install for cffi: finished with status 'error' ERROR: Complete output from command /srv/homeassistant/bin/python3 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-khjyxz8y/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-ll45jv39/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-j2_kqgp4/overlay --compile --install-headers /srv/homeassistant/include/site/python3.5/cffi: ERROR: Package libffi was not found in the pkg-config search path. Perhaps you should add the directory containing
libffi.pc’
libffi.pc’
libffi.pc’
running install
running build
running build_py
creating build
copying cffi/init.py -> build/lib.linux-armv7l-3.5/cffi
running build_ext
building ‘_cffi_backend’ extension
#include <ffi.h>
error: command ‘arm-linux-gnueabihf-gcc’ failed with exit status 1
ERROR: Command “/srv/homeassistant/bin/python3 -u -c ‘import setuptools, tokenize;file=’”’"’/tmp/pip-install-khjyxz8y/cffi/setup.py’"’"’;f=getattr(tokenize, ‘"’"‘open’"’"’, open)(file);code=f.read().replace(’"’"’\r\n’"’"’, ‘"’"’\n’"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ install --record /tmp/pip-record-ll45jv39/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-j2_kqgp4/overlay --compile --install-headers /srv/homeassistant/include/site/python3.5/cffi" failed with error code 1 in /tmp/pip-install-khjyxz8y/cffi/
ERROR: Command “/srv/homeassistant/bin/python3 /srv/homeassistant/lib/python3.5/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-j2_kqgp4/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple – ‘setuptools>=18.5’ wheel 'cffi>=1.8,!=1.11.3; python_implementation != '”’"‘PyPy’"’"’’" failed with error code 1 in None
Thank you for a hint.
