AFTER having tested the Sonoff zigbee 3 with some devices with ZHA, I updated the Sonoff Zigbee 3 in ubuntu, following Flashing the firmware via cc2538-bsl | Zigbee2MQTT
The firmware was old (2019) and I had issues with a Vimar Switch that was reported off when it was on…
After the flash everything seemed ok as following log
THEN I reinstalled the usb in the Raspi 4. and tried to delete and reinstall ZHA service…
It seemed to work (screenshot) … .at first BUT then…
The zigbee network does not work again … (screenshot, error logs)
HOW can I recover ?
Thanks in advance
Giuliano
giuliano@hotbird13:~/cc2538-bsl$ ./cc2538-bsl.py -p /dev/ttyUSB0 -evw --bootloader-sonoff-usb CC1352P2_CC2652P_launchpad_coordinator_20220219.hex
sonoff
Opening port /dev/ttyUSB0, baud 500000
Reading data from CC1352P2_CC2652P_launchpad_coordinator_20220219.hex
Your firmware looks like an Intel Hex file
Connecting to target...
CC1350 PG2.0 (7x7mm): 352KB Flash, 20KB SRAM, CCFG.BL_CONFIG at 0x00057FD8
Primary IEEE Address: 00:12:4B:00:26:B8:06:EC
Performing mass erase
Erasing all main bank flash sectors
Erase done
Writing 360448 bytes starting at address 0x00000000
Write 104 bytes at 0x00057F988
Write done
Verifying by comparing CRC32 calculations.
Verified (match: 0xddfc152d)
Logger: homeassistant.components.zha.core.gateway
Source: components/zha/core/gateway.py:173
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 10:23:07 PM (6 occurrences)
Last logged: 10:27:40 PM
Couldn't start ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2 coordinator
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/api.py", line 847, in request
response = await response_future
asyncio.exceptions.CancelledError
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 173, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.9/site-packages/zigpy/application.py", line 69, in new
await app.startup(auto_form)
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/zigbee/application.py", line 152, in startup
return await self._startup(
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/zigbee/application.py", line 318, in _startup
await self.permit(time_s=0)
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/zigbee/application.py", line 517, in permit
response = await self._znp.request_callback_rsp(
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/api.py", line 886, in request_callback_rsp
await self.request(request, **response_params)
File "/usr/local/lib/python3.9/site-packages/async_timeout/__init__.py", line 129, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.9/site-packages/async_timeout/__init__.py", line 212, in _do_exit
raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
