I’m having troubles trying to include a file using substitution:
configuration.yaml
homeassistant:
packages:
this_works: !include packages_test.yaml
error_a: !include { file: packages_test.yaml, vars: { test: 'a1' } }
error_b: !include { file: packages_test.yaml }
packages_test.yaml
mqtt:
cover:
- name: "test"
availability:
- topic: "shellies/shellyswitch25-foooo/online"
I’ve manage to found and read the following resources:
Splitting up the configuration
Packages
Reduce the size of config file (yaml) - many repeats Not Home Assistant Core
YAML <<: !include or package substitution variables? Not Home Assistant Core
And everything seems fine, but I have not much experience using YAML format. Thanks
123
(Taras)
2
The last link you provided leads to a discussion about “variable substitutions” and the following Pull Request (PR):
If you look carefully at that link, it’s a PR for ESPHome. The feature was added to ESPHome, not Home Assistant Core.
My bad. Fooled by the favicon. So, no way to use variables in that way in HA, right?
123
(Taras)
4
A search of all closed PRs in the Core repo, for “variable substitutions”, doesn’t produce any related results.
https://github.com/home-assistant/core/pulls?q=is%3Apr+is%3Aclosed+variable+substitutions
In other words, in Home Assistant, the !include directive supports a simple string argument and not ESPHome’s fancier version.
