I continued the testing and got a bit further and seemded to work, without errors but only for a short time. I now get a bunch of errors which I’m not able traceback as they do not refer to a line in the configuration file. Do you pplycky or someone else have an idea?
thanx
The code that I’m using:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 51.926393
longitude: 4.4563823
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 1
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Amsterdam
mqtt:
broker: IP RPI
port: PORT
client_id: ID
username: USER
password: PASS
input_slider:
wind_open_lim:
name: 'open at winds lower than (km/h):'
initial: 25
min: 5
max: 40
step: 1
wind_close_lim:
name: 'close at winds higher than (km/h):'
initial: 30
min: 1
max: 40
step: 1
buien_lim:
name: 'close when rain is more than (mm/h):'
initial: 0.1
min: 0.1
max: 2
step: 0.1
temp_lim:
name: 'open when temp will be more than (C):'
initial: 19
min: 15
max: 30
step: 1
input_boolean:
screen_out:
initial: off
# get some weather data
- platform: darksky
api_key: KEY
monitored_conditions:
- temperature
- precip_intensity
- precip_probability
- wind_speed
- temperature_max
- precip_intensity_max
units: si
update_interval:
minutes: 10
# buienradar did result in some timer out of sync so disabled it for the moment
# - platform: buienradar
# timeframe: 60
# monitored_conditions:
## - windgust
# - precipitation_forecast_average
# - precipitation
- platform: wunderground
api_key: KEY
- temp_c
- temp_high_1d_c
- precip_1d_mm
- precip_1d
- precip_today_metric
- wind_degrees
- wind_kph
- wind_gust_kph
- wind_gust_1d_kph
# some sensors to get the actual reading of the sliders
sensors:
show_wind_close:
friendly_name: 'show wind closing limit'
value_template: "{{ (float(states.input_slider.wind_close_lim.state)) }}"
show_wind_open:
friendly_name: 'show wind open limit'
value_template: "{{ (float(states.input_slider.wind_open_lim.state)) }}"
show_precip_lim:
friendly_name: 'show precipitation limit'
value_template: "{{ (float(states.input_slider.buien_lim.state)) }}"
show_temp_lim:
friendly_name: 'show temperature limit'
value_template: "{{ (float(states.input_slider.temp_lim.state)) }}"
screenstatus:
friendly_name: 'screen status'
value_template: >
{% if is_state('input_boolean.screen_out', 'on') %}
Open
{% else %}
Closed
{% endif %}
group:
#group the windscreen status and settings
screenstatus:
entities:
- sensor.screenstatus
- input_boolean.screen_out
- input_slider.wind_open_lim
- sensor.show_wind_open
- input_slider.wind_close_lim
- sensor.show_wind_close
- input_slider.temp_lim
- sensor.show_temp_lim
- input_slider.buien_lim
- sensor.show_precip_lim
#present the weather data
#some monitored conditions from the weather were not recognised
#as sensors and therefore not listed here
wundergrndst:
name: 'wunderground weather data'
entities:
- sensor.pws_temp_c
- sensor.pws_temp_high_1d_c
- sensor.pws_wind_degrees
- sensor.pws_wind_kph
- sensor.pws_wind_gust_kph
- sensor.pws_wind_gust_1d_kph
# buienradar:
# name: 'buienradar weather data'
# entities:
## - sensor.br_windgust
# - sensor.br_precipitation_forecast_average
darksky:
name: 'dark sky weather data'
entities:
- sensor.dark_sky_temperature
- sensor.dark_sky_precip_intensity
- sensor.dark_sky_precip_probability
- sensor.dark_sky_wind_speed
- sensor.dark_sky_temperature_max
- sensor.dark_sky_precip_intensity_max
# included in hte next template platforms the if statement with sensor = nothing as float covers all except when sensor is nothing
automation:
# open the screens
- alias: 'open screens'
# open screens when temp this day is higher than set limit
value_template: "{% if states.sensor.pws_temp_high_1d_c is undefined %}false{% elif float(states.sensor.pws_temp_high_1d_c.state,0.0) > float(states.input_slider.temp_lim.state) %}true{% else %}false{% endif %}"
value_template: "{% if states.sensor.pws_temp_c.state is undefined %}false{% elif float(states.sensor.pws_temp_c.state,0.0) > float(states.input_slider.temp_lim.state) %}true{% else %}false{% endif %}"
condition:
condition: and
conditions:
- condition: sun
after: sunrise
before: sunset
- condition: state
entity_id: input_boolean.screen_out
state: 'off'
- condition: template
value_template: "{% if states.sensor.pws_wind_gust_kph.state is undefined %}false{% elif float(states.sensor.pws_wind_gust_kph.state,states.input_slider.wind_open_lim.state+1) < float(states.input_slider.wind_open_lim.state) %}true{% else %}false{% endif %}"
#removed buienradar in bugtracking
# - condition: template
# value_template: "{% if states.sensor.br_precipitation_forecast_average is undefined %}false{% elif float(states.sensor.br_precipitation_forecast_average.state) < float(states.input_slider.buien_lim.state) %}true{% else %}false{% endif %}"
## value_template: "{% if float(states.sensor.br_precipitation.state) < float(states.input_slider.buien_lim.state) %}true{% endif %}"
# value_template: "{% if states.sensor.br_precipitation is undefined %}false{% elif float(states.sensor.br_precipitation.state) < float(states.input_slider.buien_lim.state) %}true{% else %}false{% endif %}"
#close the screens
- alias: 'close screens'
- platform: sun
event: sunset
#close in case wind is too high
value_template: "{% if states.sensor.pws_wind_gust_kph.state is undefined %}false{% elif float(states.sensor.pws_wind_gust_kph.state,0.0) > float(states.input_slider.wind_close_lim.state) %}true{% else %}false{% endif %}"
value_template: "{% if states.sensor.pws_wind_kph.state is undefined %}false{% elif float(states.sensor.pws_wind_kph.state,0.0) > float(states.input_slider.wind_close_lim.state) %}true{% else %}false{% endif %}"
#close in case it rains. removed during bugtracking
# - platform: template
# value_template: "{% if states.sensor.br_precipitation_forecast_average is undefined %}false{% elif float(states.sensor.br_precipitation_forecast_average.state) > float(states.input_slider.buien_lim.state) %}true{% else %}false{% endif %}"
# value_template: "{% if states.sensor.br_precipitation is undefined %}false{% elif float(states.sensor.br_precipitation.state) > float(states.input_slider.buien_lim.state) %}true{% else %}false{% endif %}"
condition:
- condition: state
state: 'on'
- service: input_boolean.turn_off
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
updater:
# Discover some devices automatically
discovery:
ignore:
- samsung_tv
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
logbook:
recorder:
purge_days: 8
and the errors
2017-08-03 23:19:03 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-08-03 23:19:46 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
and this one is present with regular intervals of about 5 minutes sometimes double
2017-08-03 23:43:25 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback async_track_state_change.<locals>.state_change_listener(<Event state_...131668+02:00>>) at /srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/event.py:60
File "/usr/lib/python3.4/asyncio/events.py", line 120, in _run
self._callback(*self._args)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/event.py", line 80, in state_change_listener
event.data.get('new_state'))
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/core.py", line 247, in async_run_job
target(*args)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/event.py", line 100, in template_condition_listener
template_result = condition.async_template(hass, template, variables)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/condition.py", line 296, in async_template
value = value_template.async_render(variables)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/template.py", line 101, in async_render
return self._compiled.render(kwargs).strip()
File "/srv/homeassistant/lib/python3.4/site-packages/jinja2/environment.py", line 1008, in render
return self.environment.handle_exception(exc_info, True)
File "/srv/homeassistant/lib/python3.4/site-packages/jinja2/environment.py", line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File "/srv/homeassistant/lib/python3.4/site-packages/jinja2/_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
File "/srv/homeassistant/lib/python3.4/site-packages/jinja2/sandbox.py", line 427, in call
return __context.call(__obj, *args, **kwargs)
TypeError: forgiving_float() takes 1 positional argument but 2 were given
2017-08-03 23:49:47 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal read error on socket transport
File "/usr/lib/python3.4/asyncio/selector_events.py", line 582, in _read_ready
data = self._sock.recv(self.max_size)
TimeoutError: [Errno 110] Connection timed out
