Hey, good news, if the system_log integration is running (which is required by the frontend, so it is almost certainly running in your system), then error and warning messages are available as an event. You can use the event automation trigger, with the system_log_event
event, and conditions to trigger notifications. Remember that those listed fields are available in templates as trigger.event.data.field_name
The one limitation is that this can only catch warnings/errors that occur after the integration has started, so it might miss some warnings/errors that occur really early in the boot process. However, because the front end relies on this, it is one of the integrations that gets priority loading during startup.
Hope this helps.
