Hi everyone,
I am a new user of home assistant, so I am starting from a new home-assistant installation.
I am using the current stable docker image, 0.105.5, and a Z-Wave (Sigma Designs) USB stick.
The USB stick seems to work fine, as far as I can tell.
When adding a first z-wave device, a Devolo Home Control Radiator Thermostat, the following errors are logged:
2020-02-20 00:28:55 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 360, in _async_add_entity
capabilities=entity.capability_attributes,
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 181, in capability_attributes
self.hass, self.min_temp, self.temperature_unit, self.precision
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 490, in min_temp
DEFAULT_MIN_TEMP, TEMP_CELSIUS, self.temperature_unit
File "/usr/src/homeassistant/homeassistant/util/temperature.py", line 31, in convert
raise ValueError(UNIT_NOT_RECOGNIZED_TEMPLATE.format(to_unit, TEMPERATURE))
ValueError: is not a recognized temperature unit.
and multiple times:
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 273, in async_update_ha_state
f"No entity id specified for entity {self.name}"
homeassistant.exceptions.NoEntitySpecifiedError: No entity id specified for entity Danfoss Devolo Home Control Radiator Thermostat Heating 1
Also, in Z-Wave Control Panel / Z-Wave Node Management for the new node, only the entities
sensor.danfoss_devolo_home_control_radiator_thermostat_battery_level
and sensor.danfoss_devolo_home_control_radiator_thermostat_temperature
show up.
I tried heal network
and heal node
a couple of times.
I think a climate.*
entity should also be there. There is a github issue (https://github.com/home-assistant/home-assistant/issues/29844) with the same symptom, but it is closed, so something else must be amiss here
FWIW, the configuration.yaml is
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
the included files empty.
Any ideas what’s going on here?
