Error when determing Google travel time
Error rendering data template: UndefinedError: ‘mappingproxy object’ has no attribute ‘duration_in_traffic’
This error I get while I did not touch the core settings of the sensors. The part in the configuration.yaml file is:
  • platform: google_travel_time
    name: ‘naam tot thuis’
    api_key: !secret google_api_key
    origin: device_tracker.iphone_van_naam
    destination: zone.home
Automation:
The part of the action is:
  - service: notify.ios_iphone_van_naam
    data_template:
      message: "Naam vertrekt van de AH, ze zou thuis moeten zijn in {% set travel_time = states.sensor.naam_tot_thuis.attributes.duration_in_traffic.split(' ') %} {{ travel_time[0] | int + 1 }} tot {{ travel_time[0] | int + 3 }} {{ travel_time[1] }}."
Sorry my knowledge is way too short to understand what misses but I do get the Error which I posted on the top of this topic.
According to this page
there is no duration_in_traffic. The error message is accurate.
Thank you, but can you point me in a direction what it should be? In data_template format…
Again the odd thing is, it worked until this afternoon, no problem, even after several reboots of HA :wink:
Anyway hope someone can help me to correct this.
Errors that were ignored in older versions of HA are no longer ignored.
Look at the web page link I posted & figure out a different way of stating your goal using only the available parameters.
Ok, the website I read, tweaked a setting to remove the duration in traffic to something else but no luck.
So I don’t know how to figure out so I can get an estimated time frame from A to Home.
Thanks for replying, perhaps someone else can point me in a direction of examples how to set this correct.
Entering starting point, destination and mode of travel does not give you the travel time?
I think Waze has travel time integration too.
