Hi All,
Thanks for Home Assistant - really, it’s quite awesome. I’m relatively new to using it and to the point where I would like to start contributing. I was able to successfully go through the “Set up Development Environment” guide (link) up the point where it says to run ‘script/setup’. This setup script does execute but eventually errors out and I don’t know what to do now.
Below I pasted the last bit of the script where it works and then eventually fails. (searching for ‘error’ in this text will highlight the problem) I’m running this on a clean, standard Debian installation in a virtual environment. If there is any other information that would help diagnose this problem, let me know what to provide.
Many thanks.
Complete output from command /home/wappenkunde/venv_hass/bin/python3 -u -c “import setuptools, tokenize;file=’/tmp/pip-build-_e_pq96e/sphinx-automodapi/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-15mygwg0-record/install-record.txt --single-version-externally-managed --compile --install-headers /home/wappenkunde/venv_hass/include/site/python3.4/sphinx-automodapi:
running install
running build
running build_py
creating build
creating build/lib
creating build/lib/sphinx_automodapi
copying sphinx_automodapi/automodsumm.py -> build/lib/sphinx_automodapi
copying sphinx_automodapi/smart_resolver.py -> build/lib/sphinx_automodapi
copying sphinx_automodapi/autodoc_enhancements.py -> build/lib/sphinx_automodapi
copying sphinx_automodapi/utils.py -> build/lib/sphinx_automodapi
copying sphinx_automodapi/init.py -> build/lib/sphinx_automodapi
copying sphinx_automodapi/automodapi.py -> build/lib/sphinx_automodapi
creating build/lib/sphinx_automodapi/tests
copying sphinx_automodapi/tests/test_automodsumm.py -> build/lib/sphinx_automodapi/tests
copying sphinx_automodapi/tests/test_automodapi.py -> build/lib/sphinx_automodapi/tests
copying sphinx_automodapi/tests/init.py -> build/lib/sphinx_automodapi/tests
copying sphinx_automodapi/tests/test_cases.py -> build/lib/sphinx_automodapi/tests
copying sphinx_automodapi/tests/test_utils.py -> build/lib/sphinx_automodapi/tests
creating build/lib/sphinx_automodapi/tests/example_module
copying sphinx_automodapi/tests/example_module/functions.py -> build/lib/sphinx_automodapi/tests/example_module
copying sphinx_automodapi/tests/example_module/classes.py -> build/lib/sphinx_automodapi/tests/example_module
copying sphinx_automodapi/tests/example_module/init.py -> build/lib/sphinx_automodapi/tests/example_module
creating build/lib/sphinx_automodapi/templates
creating build/lib/sphinx_automodapi/templates/autosummary_core
copying sphinx_automodapi/templates/autosummary_core/module.rst -> build/lib/sphinx_automodapi/templates/autosummary_core
copying sphinx_automodapi/templates/autosummary_core/base.rst -> build/lib/sphinx_automodapi/templates/autosummary_core
copying sphinx_automodapi/templates/autosummary_core/class.rst -> build/lib/sphinx_automodapi/templates/autosummary_core
creating build/lib/sphinx_automodapi/tests/cases
creating build/lib/sphinx_automodapi/tests/cases/mixed_toplevel_nodiagram
error: can’t copy ‘sphinx_automodapi/tests/cases/mixed_toplevel_nodiagram/output’: doesn’t exist or not a regular file
Command “/home/wappenkunde/venv_hass/bin/python3 -u -c “import setuptools, tokenize;file=’/tmp/pip-build-_e_pq96e/sphinx-automodapi/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-15mygwg0-record/install-record.txt --single-version-externally-managed --compile --install-headers /home/wappenkunde/venv_hass/include/site/python3.4/sphinx-automodapi” failed with error code 1 in /tmp/pip-build-_e_pq96e/sphinx-automodapi/
