I am using the app for my phone, and it works perfectly remotely and locally. Today I installed it on my wife’s phone. It can connect remotely but NOT locally. I am getting this error only:
Unable to connect to Home Assistant.
There was an error loading Home assistant, please review the connection settings and try again.
The settings seem to be fine (cmon, there are only 3 fields to setup)
Home assistant URL
Home Network WIFI
Internal connection URL
are all setup the same as my phone.
On your wifes phone do you need to accept a SSL cert in a browser? If so then local connection will not work as the SSL cert needs to be valid. In most cases if your router supports NAT Loopback then you want to use that and only use the external URL.
I am using ssl in my instance, so yea, I have to accept the cert. But that happens on my phone too. Why is my phone ok? Can I import the certificate somehow? I really dont want to use the loopback, since an internet interruption will render our phones useless.
Edit: Another reason I dont want the loopback, is because I intend to use the app on my tablet too (which is mounted near the entrance).
Thank you for your suggestion, but it looks like it still doesnt work. I had to convert the certificate from .pem to .crt in order to import it, but when I open the app, it doesnt work. Is there anything else I could do?
Yes I am ok now, but I dont know how I solved it, since I have a new installation of HA. The only thing I changed, is that I used the “lets encrypt” certificate method. I was using my own self signed certificate. This could be the solution.
