I’ve just moved from using a Pi 3B to a Pi 4B. Unfortunately, I also upgraded HA to 110.1 at the same time, so I can’t be sure what causes this problem.
The RFXTRX hub is plugged into a USB2 socket (tried it in the USB3 socket with no difference). The config is:
I am seeing the following in the log but cannot see why.
Logger: homeassistant.components.sensor
Source: components/rfxtrx/sensor.py:52
Integration: Sensor (documentation, issues)
First occurred: 11:22:52 (1 occurrences)
Last logged: 11:22:52
Error while setting up rfxtrx platform for sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 178, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
return fut.result()
File "/usr/src/homeassistant/homeassistant/components/rfxtrx/sensor.py", line 52, in setup_platform
device_id = "sensor_{}".format(slugify(event.device.id_string.lower()))
AttributeError: 'NoneType' object has no attribute 'device'
Curiouser and curiouser.
In an attempt to isolate the problem, I deliberately corrupted the device ID for the hub. HA should have barfed with an Error about device not found, but the log says rfxtrx was configured in 0.2 secs and there are no errors in the log.
Not sure that would throw an error, it’s just that you won’t receive anything if you have no device with this ID.
The RFX will only provide information once it receives data from the said device. It does not hold states…
it’s not incorrect info. It’s like sending a letter to the wrong address. The address itself is not incorrect, it’s just not the one where your friend lives
Checking against my config, the only difference is that my device id is not enclosed in quotes…
Though I somehow doubt that’s what it is…
@francisp I’m running Hassio Supervised (I think that’s what it is called). i.e. Hassio_supervisor running on my own Docker environment: exactly as it’s been before.
Nice thought, @francisp. I had forgotten about other services using serial devices. In this case, modem manager is not installed, but I’m going to do some digging to see if maybe something else is.
