I recently upgraded my heating system to a Vitodens 100-W boiler which includes access with the ViCare App. I have been, however, unable to complete the integration setup of the ViCare Integration as it fails on setup every time.
I have validated the username and password, the client ID, and made sure that my HA instance was up to date (different browsers, clear caches, rebuild the Client setup on the Viessman Dev site), but no matter what I try, it always fails the same way. If my HA instance is fully rebooted, it does automatically detect the ViCare device on my local network, but always fails when I attempt to complete.
My question is about the redirect URI, which I have been adding verbatim from the Integration docs. Should it not be a local IP or the public ip of my instance, or is the URI provided
vicare://oauth-callback/everest
the correct one?
Copy of error follows:
Logger: homeassistant.config_entries
Source: components/vicare/__init__.py:134
First occurred: 8:28:25 AM (2 occurrences)
Last logged: 10:23:37 AM
Error setting up entry ViCare for vicare
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 313, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/vicare/__init__.py", line 98, in async_setup_entry
await hass.async_add_executor_job(setup_vicare_api, hass, entry)
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/src/homeassistant/homeassistant/components/vicare/__init__.py", line 134, in setup_vicare_api
hass.data[DOMAIN][entry.entry_id][VICARE_CIRCUITS] = hass.data[DOMAIN][
File "/usr/local/lib/python3.9/site-packages/PyViCare/PyViCareDevice.py", line 36, in circuits
return list([self.getCircuit(x) for x in self.getAvailableCircuits()])
File "/usr/local/lib/python3.9/site-packages/PyViCare/PyViCareUtils.py", line 45, in feature_flag_wrapper
return wrapper(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/PyViCare/PyViCareUtils.py", line 38, in wrapper
return func(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/PyViCare/PyViCareDevice.py", line 265, in getAvailableCircuits
return self.service.getProperty("heating.circuits")["properties"]["enabled"]["value"]
File "/usr/local/lib/python3.9/site-packages/PyViCare/PyViCareCachedService.py", line 26, in getProperty
return readFeature(entities, property_name)
File "/usr/local/lib/python3.9/site-packages/PyViCare/PyViCareService.py", line 17, in readFeature
raise PyViCareNotSupportedFeatureError(property_name)
PyViCare.PyViCareUtils.PyViCareNotSupportedFeatureError: heating.circuits
