Hi all.
I have an Apollo MTR-1 with CO2 sensor. I was trying to add some code to make it a bluetooth tracker as well. I followed the guide as posted by homeautomationguy where you add the below code to be picked up by Format-BLE-Tracker:
mqtt:
broker: 192.168.0.110
port: 1883
username: myusername
password: mypassword
discovery: true
# Adding external component to build:
external_components:
source: github://formatBCE/ESP32_BLE_presense@main
# System time config - required for precise timestamps, used in integration:
time:
- platform: homeassistant
# Initializing it:
esp32_ble_presense:
area: "Command Centre" # Replace this with your room name
time_id: homeassistant_time
However I get an error referring to the mm-wave sensor, specifically mentioning the component is not found. It works fine without the code so it definitely is ok. This code was supposed to be able to be added to devices already doing something else but obviously something doesn’t gel well.
Can anyone please point me in the right direction? I’m still learning al this so just going through random docs hoping I’ll pick something up is not working.
Alan
