This has been working for a long time and and was not changed - but now doesnot work: This simple script which simply casts the default lovelace UI to a google nest hub max -
My dashboards on various Google Hubs have changed recently as well. Odd changes. Some tiles appear as they are supposed to but camera streams don’t, an entities list card only shows a few of the entities, a weather tile doesn’t show and other oddities. Everything appears fine on mobile or on a desktop but when the dashboard is cast they don’t work correctly. I’ve restored a backup from a few days ago and still no luck. My guess is Google changed something on their end.
Yep. Same issue here. Was working perfectly on my Google Nest. Now I can still get the nest to display my selected dashboard but only a couple of tiles show all the rest are missing. Everything looks perfect on Home Assistant web or mobile app. If anyone finds a solution please let me know, I don’t fancy uninstalling and recreating everything just to find it doesn’t solve it.
Same issue here. The state-label missing from picture elements and some mushroom entity cards, too. I cast lovelace to 2 google nest hub (one 1st gen and one 2nd gen).
@Pavel_S and @spokerevolutions, I was going to report it as a bug but I saw there are already many google cast bugs shown as open anyway for a while which is dicouraging. I am reporting it anyway as mine might be different - and here is the link to it: https://github.com/home-assistant/core/issues/88756
Seeing the same on my Google Nest Hub here. Only a few entities are showing up on the device being casted to. I’ve also tried casting to another device (Sony Bravia TV with Android TV) and it looks exactly the same, so the problem is not only with the Nest Hubs.
Also, it’s always the same entities showing up (or the same missing, if you look at it that way), so it’s not “random.”
I can confirm that my Nest Hub does not show correctly any more. I was three days away and when I came back today, an entity list did not show the content any more. Rebooting did not help
Same here, been doing some testing, and it really is card dependant, following cards do not work: Entities, sensors, and thermostat (which are basically the cards i need)
