dbemowsk
(Dan Bemowski)
September 10, 2024, 2:41am
1
So I have a switchthat I built to control the light and ceiling fan in my dining room. It runs on a Xiao ESP32-C3 MCU and has 4 buttons (2 on/off paddles). I initially set up the 4 buttons in the wrong order and the only thing I am trying to do is reorder the configuration of the buttons as to which one does what. The switch is mounted in a wall and I am pushing the firmware OTA. When I try to install the firmware with the new changes, I get this error:
ERROR Error Update end: Error: Finishing update failed. See the MQTT/USB logs for more information.
FIrst, is this error telling me that I should hard wire it to USB to see the error log? I have another switch that is an 8 button version that uses the same MCU with the only difference being the additional 4 buttons. For that one I can install the same firmware on it OTA with no trouble. I tried to clean the build files for the device and that didn’t help. I am trying to avoid having to pull the switch out of the wall to plug it in and push the firmware over USB. How can I see the logs to know what the issue is?
Any help is appreciated.
zoogara
(Daryl)
September 10, 2024, 4:15am
2
Can you move it? I have some devices that get the same error when there are wifi issues.
nickrout
(Nick Rout)
September 10, 2024, 9:03am
3
Your yaml and your complete log from the attempted update would help.
dbemowsk
(Dan Bemowski)
September 11, 2024, 6:07am
4
If there were WiFi issues, wouldn’t you think that it would fail to even upload OTA? When I run the install, it compiles, connects and uploads fine, or at least it appears to. It is after that that I see the error. As for moving it, if you read the original post, I am trying to avoid having to remove the light switch from the wall.
dbemowsk
(Dan Bemowski)
September 11, 2024, 6:15am
5
As I mentioned in the original post, I have an 8 button version of this same switch that I am able to install basically the same code, with the only differences being the name and the static IP of the device, and that uploads and works fine.
This is the complete yaml for the switch.
substitutions:
friendly_name: Dining room fan-light switch
esphome:
friendly_name: ${friendly_name}
min_version: 2024.6.0
name_add_mac_suffix: false
project:
version: dev
esp32:
board: esp32-c3-devkitm-1
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "61CokBJmkAPmaCs7t3J5etTqjJk14ldOVv3nCZJPjdI="
ota:
- platform: esphome
password: "efd7a5ab0ccffe9aecea73693045f9f7"
http_request:
useragent: esphome/dining-room-fan-light-switch
verify_ssl: false
timeout: 10s
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.1.58
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "dining-room-fan-light-switch"
password: "crSMupbq6w5R"
captive_portal:
i2c:
sda: GPIO6
scl: GPIO7
scan: False
pcf8574:
- id: 'pcf8574_hub'
address: 0x20
pcf8575: False
matrix_keypad:
rows:
- pin:
pcf8574: pcf8574_hub
number: 0
mode: OUTPUT
inverted: False
- pin:
number: 1
mode: OUTPUT
inverted: False
- pin:
number: 2
mode: OUTPUT
inverted: False
- pin:
number: 3
mode: OUTPUT
inverted: False
columns:
- pin:
number: 4
mode: INPUT
inverted: False
- pin:
number: 5
mode: INPUT
inverted: False
- pin:
number: 6
mode: INPUT
inverted: False
- pin:
number: 7
mode: INPUT
inverted: False
keys: "123A456B789C*0#D"
binary_sensor:
- platform: matrix_keypad
key: 1
on_press:
then:
- if:
condition:
wifi.connected:
then:
- http_request.get: http://192.168.1.30/control?cmd=gpio,14,1 #switch/fan/turn_off
else:
- logger.log:
format: "Error sending http_request: Wifi not connected"
level: WARN
key: 2
on_press:
then:
- if:
condition:
wifi.connected:
then:
- http_request.get: http://192.168.1.30/control?cmd=gpio,14,0 #switch/fan/turn_on
else:
- logger.log:
level: WARN
key: 4
on_press:
then:
- if:
condition:
wifi.connected:
then:
- http_request.get: http://192.168.1.30/control?cmd=gpio,27,1 #switch/light/turn_off
else:
- logger.log:
level: WARN
key: 5
on_press:
then:
- if:
condition:
wifi.connected:
then:
- http_request.get: http://192.168.1.30/control?cmd=gpio,27,0 #switch/light/turn_on
else:
- logger.log:
level: WARN
And this is the install log.
INFO ESPHome 2024.8.3
INFO Reading configuration /config/esphome/dining-room-fan-light-switch.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing dining-room-fan-light-switch (board: esp32-c3-devkitm-1; framework: arduino; platform: platformio/[email protected] )
Removing unused dependencies...
Library Manager: Installing bblanchon/ArduinoJson @ 6.18.5
INFO Installing bblanchon/ArduinoJson @ 6.18.5
Unpacking [####################################] 100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
HARDWARE: ESP32C3 160MHz, 320KB RAM, 4MB Flash
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 2.1.3
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.2.2
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- noise-c @ 0.1.6
|-- Wire @ 2.0.0
|-- ArduinoJson @ 6.18.5
|-- WiFiClientSecure @ 2.0.0
|-- HTTPClient @ 2.0.0
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/api/api_pb2_service.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/binary_sensor/automation.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/binary_sensor/binary_sensor.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/binary_sensor/filter.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/esp32/core.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/esp32/gpio.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/esp32/preferences.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/esphome/ota/ota_esphome.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/http_request/http_request.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/http_request/http_request_arduino.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/http_request/http_request_idf.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/i2c/i2c.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/i2c/i2c_bus_arduino.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/i2c/i2c_bus_esp_idf.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/json/json_util.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/key_provider/key_provider.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/logger/logger.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/logger/logger_esp32.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/logger/logger_esp8266.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/logger/logger_host.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/logger/logger_libretiny.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/logger/logger_rp2040.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/matrix_keypad/matrix_keypad.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/md5/md5.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/mdns/mdns_component.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/mdns/mdns_host.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/mdns/mdns_libretiny.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/mdns/mdns_rp2040.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/network/util.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/ota/ota_backend.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/ota/ota_backend_arduino_libretiny.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/ota/ota_backend_arduino_rp2040.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/pcf8574/pcf8574.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/safe_mode/safe_mode.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/socket/lwip_sockets_impl.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/socket/socket.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/watchdog/watchdog.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/wifi/wifi_component.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/wifi/wifi_component_libretiny.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/components/wifi/wifi_component_pico_w.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/core/application.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/core/bytebuffer.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/core/color.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/core/component.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/core/component_iterator.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/core/controller.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/core/entity_base.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/core/helpers.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/core/log.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/core/ring_buffer.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/core/scheduler.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/core/time.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/core/string_ref.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/esphome/core/util.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/src/main.cpp.o
Building .pioenvs/dining-room-fan-light-switch/bootloader.bin
Creating esp32c3 image...
Successfully created esp32c3 image.
Generating partitions .pioenvs/dining-room-fan-light-switch/partitions.bin
Compiling .pioenvs/dining-room-fan-light-switch/libef6/AsyncTCP-esphome/AsyncTCP.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib64d/WiFi/WiFi.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib64d/WiFi/WiFiAP.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib64d/WiFi/WiFiClient.cpp.o
Archiving .pioenvs/dining-room-fan-light-switch/libef6/libAsyncTCP-esphome.a
Compiling .pioenvs/dining-room-fan-light-switch/lib64d/WiFi/WiFiGeneric.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib64d/WiFi/WiFiMulti.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib64d/WiFi/WiFiSTA.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib64d/WiFi/WiFiScan.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib64d/WiFi/WiFiServer.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib64d/WiFi/WiFiUdp.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib01c/FS/FS.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib01c/FS/vfs_api.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/libbc6/Update/HttpsOTAUpdate.cpp.o
Archiving .pioenvs/dining-room-fan-light-switch/lib64d/libWiFi.a
Compiling .pioenvs/dining-room-fan-light-switch/libbc6/Update/Updater.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib3f8/ESPAsyncWebServer-esphome/AsyncEventSource.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib3f8/ESPAsyncWebServer-esphome/AsyncWebSocket.cpp.o
Archiving .pioenvs/dining-room-fan-light-switch/lib01c/libFS.a
Compiling .pioenvs/dining-room-fan-light-switch/lib3f8/ESPAsyncWebServer-esphome/WebAuthentication.cpp.o
Archiving .pioenvs/dining-room-fan-light-switch/libbc6/libUpdate.a
Compiling .pioenvs/dining-room-fan-light-switch/lib3f8/ESPAsyncWebServer-esphome/WebHandlers.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib3f8/ESPAsyncWebServer-esphome/WebRequest.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib3f8/ESPAsyncWebServer-esphome/WebResponses.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib3f8/ESPAsyncWebServer-esphome/WebServer.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib333/DNSServer/DNSServer.cpp.o
Archiving .pioenvs/dining-room-fan-light-switch/lib333/libDNSServer.a
Compiling .pioenvs/dining-room-fan-light-switch/lib915/ESPmDNS/ESPmDNS.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_aead/chacha20poly1305/sodium/aead_chacha20poly1305.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_core/ed25519/core_ed25519.c.o
Archiving .pioenvs/dining-room-fan-light-switch/lib3f8/libESPAsyncWebServer-esphome.a
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_core/ed25519/core_ristretto255.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_core/ed25519/ref10/ed25519_ref10.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_core/salsa/ref/core_salsa_ref.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_generichash/blake2b/generichash_blake2.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-avx2.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-ref.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-sse41.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_generichash/blake2b/ref/blake2b-compress-ssse3.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_generichash/blake2b/ref/blake2b-ref.c.o
Archiving .pioenvs/dining-room-fan-light-switch/lib915/libESPmDNS.a
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_generichash/blake2b/ref/generichash_blake2b.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_hash/crypto_hash.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_hash/sha256/cp/hash_sha256_cp.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_hash/sha256/hash_sha256.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_hash/sha512/cp/hash_sha512_cp.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_hash/sha512/hash_sha512.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_onetimeauth/crypto_onetimeauth.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_pwhash/argon2/argon2-core.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_pwhash/argon2/argon2-encoding.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_pwhash/argon2/argon2-fill-block-avx2.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_pwhash/argon2/argon2-fill-block-avx512f.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_pwhash/argon2/argon2-fill-block-ref.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_pwhash/argon2/argon2-fill-block-ssse3.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_pwhash/argon2/argon2.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_pwhash/argon2/blake2b-long.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_pwhash/argon2/pwhash_argon2i.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_pwhash/argon2/pwhash_argon2id.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_scalarmult/crypto_scalarmult.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_scalarmult/curve25519/ref10/x25519_ref10.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_scalarmult/curve25519/scalarmult_curve25519.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_sign/crypto_sign.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_sign/ed25519/ref10/keypair.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_sign/ed25519/ref10/obsolete.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_sign/ed25519/ref10/open.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_sign/ed25519/ref10/sign.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_sign/ed25519/sign_ed25519.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_stream/chacha20/ref/chacha20_ref.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_stream/chacha20/stream_chacha20.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_stream/crypto_stream.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_stream/salsa20/ref/salsa20_ref.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_stream/salsa20/stream_salsa20.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_stream/salsa20/xmm6/salsa20_xmm6-asm.S.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_stream/salsa20/xmm6/salsa20_xmm6.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_stream/salsa20/xmm6int/salsa20_xmm6int-avx2.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_stream/salsa20/xmm6int/salsa20_xmm6int-sse2.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/crypto_verify/sodium/verify.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/randombytes/internal/randombytes_internal_random.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/randombytes/randombytes.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/randombytes/sysrandom/randombytes_sysrandom.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/sodium/codecs.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/sodium/core.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/sodium/runtime.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libaa5/libsodium/sodium/utils.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/backend/openssl/cipher-aesgcm.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/backend/ref/cipher-aesgcm.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/backend/ref/cipher-chachapoly.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/backend/ref/dh-curve25519.c.o
Archiving .pioenvs/dining-room-fan-light-switch/libaa5/libsodium.a
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/backend/ref/hash-blake2b.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/backend/ref/hash-blake2s.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/backend/ref/hash-sha256.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/backend/sodium/cipher-aesgcm.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/backend/sodium/cipher-chachapoly.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/backend/sodium/dh-curve25519.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/backend/sodium/hash-blake2b.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/backend/sodium/hash-sha256.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/crypto/aes/rijndael-alg-fst.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/crypto/blake2/blake2b.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/crypto/blake2/blake2s.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/crypto/chacha/chacha.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/crypto/donna/curve25519-donna-c64.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/crypto/donna/curve25519-donna.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/crypto/donna/poly1305-donna.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/crypto/sha2/sha256.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/crypto/sha2/sha512.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/crypto/x25519/x25519.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/protocol/cipherstate.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/protocol/dhstate.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/protocol/errors.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/protocol/handshakestate.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/protocol/hashstate.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/protocol/internal.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/protocol/names.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/protocol/patterns.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/protocol/rand_os.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/protocol/rand_sodium.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/protocol/randstate.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/protocol/signstate.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/protocol/symmetricstate.c.o
Compiling .pioenvs/dining-room-fan-light-switch/liba63/noise-c/protocol/util.c.o
Compiling .pioenvs/dining-room-fan-light-switch/lib4fc/Wire/Wire.cpp.o
Archiving .pioenvs/dining-room-fan-light-switch/liba63/libnoise-c.a
Compiling .pioenvs/dining-room-fan-light-switch/libb0f/WiFiClientSecure/WiFiClientSecure.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/libb0f/WiFiClientSecure/esp_crt_bundle.c.o
Compiling .pioenvs/dining-room-fan-light-switch/libb0f/WiFiClientSecure/ssl_client.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/lib2f0/HTTPClient/HTTPClient.cpp.o
Archiving .pioenvs/dining-room-fan-light-switch/lib4fc/libWire.a
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/Esp.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/FirmwareMSC.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/FunctionalInterrupt.cpp.o
Archiving .pioenvs/dining-room-fan-light-switch/libb0f/libWiFiClientSecure.a
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/HWCDC.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/IPAddress.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/IPv6Address.cpp.o
Archiving .pioenvs/dining-room-fan-light-switch/lib2f0/libHTTPClient.a
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/MD5Builder.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/Print.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/Stream.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/StreamString.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/Tone.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/USB.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/USBCDC.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/USBMSC.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/WMath.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/WString.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/base64.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/cbuf.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-adc.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-bt.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-cpu.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-dac.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-gpio.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-i2c-slave.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-i2c.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-ledc.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-matrix.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-misc.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-psram.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-rgb-led.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-rmt.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-sigmadelta.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-spi.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-time.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-timer.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-tinyusb.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-touch.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/esp32-hal-uart.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/firmware_msc_fat.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/libb64/cdecode.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/libb64/cencode.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/main.cpp.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/stdlib_noniso.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/wiring_pulse.c.o
Compiling .pioenvs/dining-room-fan-light-switch/FrameworkArduino/wiring_shift.c.o
Archiving .pioenvs/dining-room-fan-light-switch/libFrameworkArduino.a
Linking .pioenvs/dining-room-fan-light-switch/firmware.elf
RAM: [= ] 11.6% (used 38028 bytes from 327680 bytes)
Flash: [====== ] 60.3% (used 1107122 bytes from 1835008 bytes)
Building .pioenvs/dining-room-fan-light-switch/firmware.bin
esp32_create_combined_bin([".pioenvs/dining-room-fan-light-switch/firmware.bin"], [".pioenvs/dining-room-fan-light-switch/firmware.elf"])
Wrote 0x121da0 bytes to file /data/build/dining-room-fan-light-switch/.pioenvs/dining-room-fan-light-switch/firmware.factory.bin, ready to flash to offset 0x0
esp32_copy_ota_bin([".pioenvs/dining-room-fan-light-switch/firmware.bin"], [".pioenvs/dining-room-fan-light-switch/firmware.elf"])
========================= [SUCCESS] Took 39.94 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.1.58
INFO Uploading /data/build/dining-room-fan-light-switch/.pioenvs/dining-room-fan-light-switch/firmware.bin (1121696 bytes)
Uploading: [============================================================] 100% Done...
INFO Upload took 10.83 seconds, waiting for result...
Roger954
(Roger)
April 8, 2025, 2:43pm
6
Did you solve this? I’ve got the same error, can’t install modified YAML code wireless anymore. The ESPHome device (Firmware: 1.2.0 (ESPHome 2025.3.3)) is connected to wifi, working fine…
I am having the same issue.
Was anyone able to fix it?
Krivatri
(Krivatri)
June 26, 2025, 8:35am
8
did OTA update work before?
I had a similar issue with smart plugs I had wirelessly flashed with ESPHome.
flashing worked fine, but wasn’t able to do OTA afterwards, if I’m not mistaken, it had something to do with the esp partition table?
the solution for me was to open up the devices and flash them through UART.
ageurtse
(Arnold)
September 6, 2025, 9:45am
9
For me this error occured when switching from esp-idf to arduino, after flashing by wire, the wireless update process looks good again.
