Hi! I can’t seem to get this Add-on to install. Here are the Supervisor logs:
make: Leaving directory '/workspace/node_modules/bufferutil/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack at ChildProcess.emit (events.js:400:28)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:285:12)
gyp ERR! System Linux 6.1.73-haos-raspi
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /workspace/node_modules/bufferutil
gyp ERR! node -v v14.21.3
gyp ERR! node-gyp -v v5.1.1
gyp ERR! not ok
npm WARN [email protected] No description
npm WARN [email protected] No repository field.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] install: `node-gyp-build`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm
ERR! A complete log of this run can be found in:
npm
ERR!
/root/.npm/_logs/2024-05-05T09_41_10_183Z-debug.log
---> Removed intermediate container f8356b5c7ff4
I’m afraid I have absolutely no idea what it’s saying!
