HI All,
So i follow the online guide for installing homeassistant on Syno that doesnt have docker (DS213)
https://www.home-assistant.io/docs/installation/synology/
But i run into trouble installing the multidict when running this :
./python3 -m pip install homeassistant==0.64.3
The error i get. Any help would be appreciated
ERROR: Command errored out with exit status 1:
command: /volume1/@appstore/py3k/usr/local/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-7owfzyzf/multidict/setup.py'"'"'; __file__='"'"'/tmp/pip-install-7owfzyzf/multidict/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-58hz6dbs/install-record.txt --single-version-externally-managed --compile
cwd: /tmp/pip-install-7owfzyzf/multidict/
Complete output (44 lines):
* Accellerated build *
running install
running build
running build_py
creating build
creating build/lib.linux-armv5tel-3.5
creating build/lib.linux-armv5tel-3.5/multidict
copying multidict/_multidict_py.py -> build/lib.linux-armv5tel-3.5/multidict
copying multidict/_multidict_base.py -> build/lib.linux-armv5tel-3.5/multidict
copying multidict/_compat.py -> build/lib.linux-armv5tel-3.5/multidict
copying multidict/_abc.py -> build/lib.linux-armv5tel-3.5/multidict
copying multidict/__init__.py -> build/lib.linux-armv5tel-3.5/multidict
running egg_info
writing multidict.egg-info/PKG-INFO
writing top-level names to multidict.egg-info/top_level.txt
writing dependency_links to multidict.egg-info/dependency_links.txt
reading manifest file 'multidict.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no previously-included files matching '*.pyc' found anywhere in distribution
warning: no previously-included files found matching 'multidict/_multidict.html'
warning: no previously-included files found matching 'multidict/*.so'
warning: no previously-included files found matching 'multidict/*.pyd'
no previously-included directories found matching 'docs/_build'
writing manifest file 'multidict.egg-info/SOURCES.txt'
copying multidict/__init__.pyi -> build/lib.linux-armv5tel-3.5/multidict
copying multidict/_multidict.c -> build/lib.linux-armv5tel-3.5/multidict
copying multidict/py.typed -> build/lib.linux-armv5tel-3.5/multidict
creating build/lib.linux-armv5tel-3.5/multidict/_multilib
copying multidict/_multilib/defs.h -> build/lib.linux-armv5tel-3.5/multidict/_multilib
copying multidict/_multilib/dict.h -> build/lib.linux-armv5tel-3.5/multidict/_multilib
copying multidict/_multilib/istr.h -> build/lib.linux-armv5tel-3.5/multidict/_multilib
copying multidict/_multilib/iter.h -> build/lib.linux-armv5tel-3.5/multidict/_multilib
copying multidict/_multilib/pair_list.h -> build/lib.linux-armv5tel-3.5/multidict/_multilib
copying multidict/_multilib/views.h -> build/lib.linux-armv5tel-3.5/multidict/_multilib
running build_ext
building 'multidict._multidict' extension
creating build/temp.linux-armv5tel-3.5
creating build/temp.linux-armv5tel-3.5/multidict
/usr/local/arm-marvell-linux-gnueabi/bin/arm-marvell-linux-gnueabi-ccache-gcc -Wno-unused-result -Wsign-compare -Wunreachable-code -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -DSYNO_FIX_FLAG_BUG -DOPENSSL_NO_SSL3 -DOPENSSL_NO_SSL2 -DSYNOPLAT_F_ARMV5 -O2 -mcpu=marvell-f -include /usr/syno/include/platformconfig.h -DSYNO_ENVIRONMENT -DBUILD_ARCH=32 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -g -DSDK_VER_MIN_REQUIRED=600 -pipe -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -D_FORTIFY_SOURCE=2 -O2 -Wno-unused-result -fPIC -I/volume1/@appstore/py3k/usr/local/include/python3.5m -c multidict/_multidict.c -o build/temp.linux-armv5tel-3.5/multidict/_multidict.o -O2 -std=c99 -Wall -Wsign-compare -Wconversion -fno-strict-aliasing -pedantic
unable to execute '/usr/local/arm-marvell-linux-gnueabi/bin/arm-marvell-linux-gnueabi-ccache-gcc': No such file or directory
error: command '/usr/local/arm-marvell-linux-gnueabi/bin/arm-marvell-linux-gnueabi-ccache-gcc' failed with exit status 1
ERROR: Command errored out with exit status 1: /volume1/@appstore/py3k/usr/local/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-7owfzyzf/multidict/setup.py'"'"'; __file__='"'"'/tmp/pip-install-7owfzyzf/multidict/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-58hz6dbs/install-record.txt --single-version-externally-managed --compile Check the logs for full command output.
