I tried to add a simple light in the yaml conf file, but the system console says that something is wrong. Below is the content of the conf file.
In addition: which utility can I use to check the configuration error?
The documentation says:
hass --script check_config
. On Hass.io you can use the hassio command: hassio homeassistant check
but I don’t have nor “hassio” program, nor “hass” (I installed hassio on raspbian with
“curl -sL https://raw.githubusercontent.com/home-assistant/hassio-build/master/install/hassio_install | sudo bash -s – -m raspberrypi3”
and I only have “hassio-supervisor” executable.
Thanks for your help
homeassistant:
Name of the location where Home Assistant is running
Location required to calculate the time the sun rises and sets
latitude: 41.9569
longitude: 15.0355
Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
metric for Metric, imperial for Imperial
unit_system: metric
Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Rome
Customization file
customize: !include customize.yaml
Show links to resources in log and frontend
introduction:
Enables the frontend
frontend:
Enables configuration UI
config:
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: example.duckdns.org:8123
Checks for available updates
Note: This component will send some information about your system to
the developers to assist with development of Home Assistant.
For more information, please see:
https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
Optional, allows Home Assistant developers to focus on popular components.
include_used_components: true
Discover some devices automatically
discovery:
Allows you to issue voice commands from the frontend in enabled browsers
conversation:
Enables support for tracking state changes over time
history:
View all events in a logbook
logbook:
Enables a map showing the location of tracked devices
map:
Track the sun
sun:
Allow diagnosing system problems
system_health:
Sensors
Weather prediction
- platform: yr
Text to speech
tts:
- platform: google
Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
light:
- platform: mqtt
view: yes
state_topic: “office/light/status”
command_topic: “office/light/switch”
payload_off: “OFF”
brightness_state_topic: ‘office/light/brightness’
brightness_command_topic: ‘office/light/brightness/set’
on_command_type: ‘brightness’
