Error while calling rebuildNodeRoutes: Node undefined not found
Hi all,
I had to replace a dead zwave switch. I forced the removal of the dead switch, installed the new one, and overall it appears to be working fine now. I figured it would be a good idea to rebuild all the routes so I tried doing that, but when I do I get this message and it doesn’t appear that any of the nodes try to rebuild their routes:
And I’m currently using:
Core 2024.8.2
Supervisor 2024.08.0
Operating System 13.1
Frontend 20240809.0
And also:
zwave-js-ui: 9.17.0
zwave-js: 13.1.0
How do I track down this undefined node and get rid of it so that I can run a full rebuild of the routes? I’m able to rebuild nodes one-by-one, but I don’t want to have to do that for all my devices if I don’t have to.
a) you should rebuild routes one by one starting with your closest power nodes
b) you may not need to do that as zwave will adjust routes
Restarting zwavejs may fix the issue you have.
