Error While Creating a Full Backup "Please Supply Your Ring Credentials" (I Don't Have Ring Devices)
I am getting an error that mentions ring longing except I don’t have any ring devices or any kind of ring plugin, unless that’s the Alex Media Player?
2024-11-05 11:10:00.600 WARNING (SyncWorker_3) [supervisor.store.data] Can’t read /data/addons/git/09e60fb6/external/ring-client-api/packages/homebridge-ring/config.schema.json: Invalid Add-on config!. Got {‘pluginAlias’: ‘Ring’, ‘pluginType’: ‘platform’, ‘singular’: True, ‘customUi’: True, ‘customUiPath’: ‘./lib/homebridge-ui’, ‘customUiDevServer’: ‘http://localhost:3000/api/plugins/settings-ui/homebridge-ring’, ‘headerDisplay’: ‘See the wiki for details on generating a refresh token’, ‘accountLinkingHeader’: 'Please supply your Ring credentials. These will be used to contact the Ring servers and generate a unique access token for your acc…
2024-11-05 11:10:01.426 WARNING (SyncWorker_7) [supervisor.store.data] Can’t read /data/addons/git/09e60fb6/external/ring-client-api/packages/homebridge-ring/config.schema.json: Invalid Add-on config!. Got {‘pluginAlias’: ‘Ring’, ‘pluginType’: ‘platform’, ‘singular’: True, ‘customUi’: True, ‘customUiPath’: ‘./lib/homebridge-ui’, ‘customUiDevServer’: ‘http://localhost:3000/api/plugins/settings-ui/homebridge-ring’, ‘headerDisplay’: ‘See the wiki for details on generating a refresh token’, ‘accountLinkingHeader’: 'Please supply your Ring credentials. These will be used to contact the Ring servers and generate a unique access token for your acc…
Are you using the homebridge integration?
