Error while dialing dial unix /var/run/docker/containerd.sock: connect: connection refused
After a power faillure HA is stuck on this screen.
I’m running Homeassistant OS on a mini PC
waiting for the home assistant cli to be ready
connection error: desc = "transport: Error while dialing dial unix /var/run/docker/containerd.sock: connect: connection refused": unavailable"
hi @Fabian02 ! were you able to figure it out? i am getting the same error here:
