Hi I’m new to HA and I have esp32 which connected to HA with esphome it was fine but I wanted to add a fan speed vis pulse counter I added a some code with the help of chatGPT and when trying to install the code it gives error like this
INFO ESPHome 2024.6.1
INFO Reading configuration /config/esphome/esp32.yaml...
ERROR Error while reading config: Invalid YAML syntax:
while parsing a block collection
in "/config/esphome/esp32.yaml", line 21, column 3
expected <block end>, but found '?'
in "/config/esphome/esp32.yaml", line 22, column 3
what can I do the yaml code is
esphome:
friendly_name: esp32
esp32:
board: esp32dev
framework:
type: arduino
esp32_ble_tracker:
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "C6DjitzRd+jL69UDVzf1HLWylW3Ll9tqsTjcyi6oevk="
ota:
- platform: esphome
safe_mode: true
password: "63bbbcceb4ee9f51f22133e05973b2e2"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esp32 Fallback Hotspot"
password: "uG9oitEfhffe"
captive_portal:
- platform: atc_mithermometer
mac_address: "A4:C1:38:5F:B8:F3"
temperature:
name: "ATC Temperature"
humidity:
name: "ATC Humidity"
battery_level:
name: "ATC Battery-Level"
battery_voltage:
name: "ATC Battery-Voltage"
signal_strength:
- platform: pulse_counter
pin: GPIO16 # Change this to the GPIO pin you're using
unit_of_measurement: "rpm"
icon: "mdi:fan"
update_interval: 60s
filters:
- multiply: 0.5 # Adjust this value based on your fan's tachometer specifications
count_mode:
rising_edge: true
falling_edge: false
