HI All,
I get this error for some one my sensors when I restart HA, Zwave device is not ready at moment when HA was restarted.
Can someone tell me how to solve this?
2020-12-24 10:20:52 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template("{{ (states.sensor.zwave2mqtt_nodeid_77_electricity_kwh_meter.attributes.value) | float('Unavailable') }}")
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 353, in async_render
render_result = compiled.render(kwargs)
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 1090, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 832, in handle_exception
reraise(*rewrite_traceback_stack(source=source))
File "/usr/local/lib/python3.8/site-packages/jinja2/_compat.py", line 28, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
File "/usr/local/lib/python3.8/site-packages/jinja2/filters.py", line 794, in do_float
return float(value)
jinja2.exceptions.UndefinedError: 'mappingproxy object' has no attribute 'value'
binary_sensor:
washing_machine:
friendly_name: "Washing machine"
value_template: "{{ states('sensor.zwave2mqtt_nodeid_77_electricity_w_meter') | float(0) > 5 }}"
attribute_templates:
kwh: "{{ (states.sensor.zwave2mqtt_nodeid_77_electricity_kwh_meter.attributes.value) | float('Unavailable') }}"
washing_machine:
friendly_name: "Washing Machine kWh"
value_template: "{{ (states.sensor.zwave2mqtt_nodeid_77_electricity_kwh_meter.attributes.value) | float('Unavailable') }}"
