After one of the latest 0.43.X updated my system has gone haywire, Sonos isn’t working and Hue is very unreliable. I see this in my log after a reboot… I’ve tried a few things but nothing helps…
Z-Wave seams to work OK though.
Has anyone seen this and resolved it?
17-05-01 22:27:22 ERROR (MainThread) [homeassistant.components.media_player] Error while setting up platform sonos
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py", line 83, in create_connection
raise err
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py", line 73, in create_connection
sock.connect(sa)
TimeoutError: [Errno 110] Connection timed out
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 356, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/lib/python3.4/http/client.py", line 1090, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.4/http/client.py", line 1128, in _send_request
self.endheaders(body)
File "/usr/lib/python3.4/http/client.py", line 1086, in endheaders
self._send_output(message_body)
File "/usr/lib/python3.4/http/client.py", line 924, in _send_output
self.send(msg)
File "/usr/lib/python3.4/http/client.py", line 859, in send
self.connect()
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 166, in connect
conn = self._new_conn()
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 150, in _new_conn
self, "Failed to establish a new connection: %s" % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.HTTPConnection object at 0x685c8350>: Failed to establish a new connection: [Errno 110] Connection timed out
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/adapters.py", line 423, in send
timeout=timeout
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 649, in urlopen
_stacktrace=sys.exc_info()[2])
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/util/retry.py", line 376, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='40.0.0.11', port=1400): Max retries exceeded with url: /ZoneGroupTopology/Control (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x685c8350>: Failed to establish a new connection: [Errno 110] Connection timed out',))
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 155, in _async_setup_platform
entity_platform.schedule_add_entities, discovery_info
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/media_player/sonos.py", line 109, in setup_platform
if player.uid in [x.unique_id for x in hass.data[DATA_SONOS]]:
File "/home/homeassistant/.homeassistant/deps/soco/core.py", line 271, in uid
self._parse_zone_group_state()
File "/home/homeassistant/.homeassistant/deps/soco/core.py", line 775, in _parse_zone_group_state
cache_timeout=5)['ZoneGroupState']
File "/home/homeassistant/.homeassistant/deps/soco/services.py", line 656, in GetZoneGroupState
return self.send_command('GetZoneGroupState', *args, **kwargs)
File "/home/homeassistant/.homeassistant/deps/soco/services.py", line 387, in send_command
data=body.encode('utf-8')
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/api.py", line 110, in post
return request('post', url, data=data, json=json, **kwargs)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/api.py", line 56, in request
return session.request(method=method, url=url, **kwargs)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/sessions.py", line 488, in request
resp = self.send(prep, **send_kwargs)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/sessions.py", line 609, in send
r = adapter.send(request, **kwargs)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/adapters.py", line 487, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='40.0.0.11', port=1400): Max retries exceeded with url: /ZoneGroupTopology/Control (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x685c8350>: Failed to establish a new connection: [Errno 110] Connection timed out',))
17-05-01 22:27:30 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
