hope this is the right forum. I am still new to Home Assistant. I have my Hassio on a RPI3 and want to setup Zigbee2Mqtt with the CC2531 sniffer. I’ve followed the guide to flashing the dongle and that all seemed to work as it should
I’ve then added the danielwelch rep from https://github.com/danielwelch/hassio-zigbee2mqtt but when I press install under the add-ons, the buttom turns red after a few sec and I get the following error
19-03-09 05:42:55 INFO (SyncWorker_2) [hassio.docker.interface] Pull image dwelch2101/zigbee2mqtt-armv7 tag 1.1.1.
`19-03-09 05:42:58 ERROR (SyncWorker_2) [hassio.docker.interface] Can't install dwelch2101/zigbee2mqtt-armv7:1.1.1 -> 404 Client Error: Not Found ("pull access denied for dwelch2101/zigbee2mqtt-armv7, repository does not exist or may require 'docker login'").`
I’ve tried googling every part of the error message, but been unable to find anything so solve my issue, so I hope some of your good people might be able to help me
I have it running I confirm I use the same add on repro as you’re using. Not sure if it is down temporarily?
Are you able to pull other addons from that repro or other repro?
Thanks for answering. There is only the two apps on the reb, the zigbee2mqtt and then the edge version. Neither are able to pull
I tried installing other apps from the main rep and that worked fine !
Partly true. Hassio added support for an additional architecture, armv7. The add-on does not specify which architectures it supports, hence Hass.io assumes it supports all, which it doesn’t. I’ve opened a PR to correct that.
