I use this codes to update HA ,but got an error
pip3 install --upgrade homeassistant
pip3 install --upgrade homeassistant --no-cache-dir
the error is
Exception: Traceback (most recent call last): File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connection.py", line 138, in _new_conn (self.host, self.port), self.timeout, **extra_kw) File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/connection.py", line 98, in create_connection raise err File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/connection.py", line 88, in create_connection sock.connect(sa) OSError: [Errno 101] Network is unreachable During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 594, in urlopen chunked=chunked) File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 350, in _make_request self._validate_conn(conn) File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 837, in _validate_conn conn.connect() File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connection.py", line 281, in connect conn = self._new_conn() File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connection.py", line 147, in _new_conn self, "Failed to establish a new connection: %s" % e) pip._vendor.requests.packages.urllib3.exceptions.NewConnectionError: <pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x75d61a70>: Failed to establish a new connection: [Errno 101] Network is unreachable During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/pip/basecommand.py", line 215, in main status = self.run(options, args) File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 342, in run requirement_set.prepare_files(finder) File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 380, in prepare_files ignore_dependencies=self.ignore_dependencies)) File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 554, in _prepare_file require_hashes File "/usr/lib/python3/dist-packages/pip/req/req_install.py", line 278, in populate_link self.link = finder.find_requirement(self, upgrade) File "/usr/lib/python3/dist-packages/pip/index.py", line 465, in find_requirement all_candidates = self.find_all_candidates(req.name) File "/usr/lib/python3/dist-packages/pip/index.py", line 423, in find_all_candidates for page in self._get_pages(url_locations, project_name): File "/usr/lib/python3/dist-packages/pip/index.py", line 568, in _get_pages page = self._get_page(location) File "/usr/lib/python3/dist-packages/pip/index.py", line 683, in _get_page return HTMLPage.get_page(link, session=self.session) File "/usr/lib/python3/dist-packages/pip/index.py", line 792, in get_page "Cache-Control": "max-age=600", File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 501, in get return self.request('GET', url, **kwargs) File "/usr/lib/python3/dist-packages/pip/download.py", line 386, in request return super(PipSession, self).request(method, url, *args, **kwargs) File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 488, in request resp = self.send(prep, **send_kwargs) File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 609, in send r = adapter.send(request, **kwargs) File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py", line 423, in send timeout=timeout File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 643, in urlopen _stacktrace=sys.exc_info()[2]) File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/retry.py", line 315, in increment total -= 1 TypeError: unsupported operand type(s) for -=: 'Retry' and 'int'
So how could I update it ?
