Hi All -
Having a strange error that I can’t get to the bottom of. I am running Home Assistant Operating System on a RPI 4.
My installation is working ok, but I noticed that the ‘Check Configuration’ button under ‘Configuration’ → ‘Server Controls’ hangs, and the ‘Restart Server’ link fails. Looking at the log files, I see this error at startup:
2021-05-28 17:43:57 ERROR (MainThread) [homeassistant.setup] Setup failed for zeroconf: unknown error
File "/usr/src/homeassistant/homeassistant/setup.py", line 200, in _async_setup_component
component = integration.get_component()
File "/usr/src/homeassistant/homeassistant/loader.py", line 485, in get_component
cache[self.domain] = importlib.import_module(self.pkg_path)
File "/usr/local/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 783, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/usr/src/homeassistant/homeassistant/components/zeroconf/__init__.py", line 14, in <module>
from pyroute2 import IPRoute
File "/usr/local/lib/python3.8/site-packages/pyroute2/__init__.py", line 104, in <module>
from pyroute2.cli.console import Console
File "/usr/local/lib/python3.8/site-packages/pyroute2/cli/console.py", line 14, in <module>
class Console(code.InteractiveConsole):
AttributeError: module 'code' has no attribute 'InteractiveConsole'
But I am having trouble understanding where it is coming from - I assume it is some interaction with another addon or integration. If I recover from my last full snapshot (2021.3.2) everything works perfectly. If I then just update to 2021.5.5 (leaving all other addons and config the same), I get the error again. I have tried a complete clean install and recovery from the snapshot, but see the same behaviour on upgrading home assistant.
I’m unsure how to even begin investigating - any ideas?
TIA.
