with the upgrade from v0.41 to the latest version, I get multiple errors in the latest version of aoihttp. Downgrading back to v0.41 resolves the error.
the error I get is as follows:
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.history. Make sure all dependencies are installed
File "/usr/local/lib/python3.5/dist-packages/homeassistant/loader.py", line 141, in get_component
module = importlib.import_module(path)
File "/usr/lib/python3.5/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 986, in _gcd_import
File "<frozen importlib._bootstrap>", line 969, in _find_and_load
File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 665, in exec_module
File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_removed
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/history.py", line 20, in <module>
from homeassistant.components.frontend import register_built_in_panel
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/frontend/__init__.py", line 12, in <module>
from homeassistant.components import api, group
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/api.py", line 26, in <module>
from homeassistant.helpers.state import AsyncTrackStates
File "/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/state.py", line 8, in <module>
from homeassistant.components.media_player import (
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/media_player/__init__.py", line 24, in <module>
from homeassistant.components.http import HomeAssistantView, KEY_AUTHENTICATED
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/http/__init__.py", line 33, in <module>
from .static import (
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/http/static.py", line 6, in <module>
from aiohttp.web import FileResponse
ImportError: cannot import name 'FileResponse'
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.loader] Unable to find component history
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Component not found.
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.frontend. Make sure all dependencies are installed
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.loader] Unable to find component frontend
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Component not found.
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.http. Make sure all dependencies are installed
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.loader] Unable to find component http
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.setup] Setup failed for http: Component not found.
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of mqtt.server. Setup failed for dependencies: http
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform mqtt.server: Could not setup all dependencies.
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.components.mqtt] Unable to load embedded server
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.components.mqtt] Unable to start MQTT broker.
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.setup] Setup failed for mqtt: Component failed to initialize.
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.automation. Make sure all dependencies are installed
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/automation/__init__.py", line 20, in <module>
from homeassistant.components import logbook
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/logbook.py", line 18, in <module>
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.loader] Unable to find component automation
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.setup] Setup failed for automation: Component not found.
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.device_tracker. Make sure all dependencies are installed
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/device_tracker/__init__.py", line 27, in <module>
from homeassistant.helpers.restore_state import async_get_last_state
File "/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/restore_state.py", line 10, in <module>
from homeassistant.components.history import get_states, last_recorder_run
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.loader] Unable to find component device_tracker
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.setup] Setup failed for device_tracker: Component not found.
17-04-24 21:03:33 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.media_player. Make sure all dependencies are installed
17-04-24 21:03:34 ERROR (MainThread) [homeassistant.loader] Unable to find component media_player
17-04-24 21:03:34 ERROR (MainThread) [homeassistant.setup] Setup failed for media_player: Component not found.
17-04-24 21:03:34 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.logbook. Make sure all dependencies are installed
17-04-24 21:03:34 ERROR (MainThread) [homeassistant.loader] Unable to find component logbook
17-04-24 21:03:34 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Component not found.
17-04-24 21:03:34 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.light. Make sure all dependencies are installed
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/light/__init__.py", line 25, in <module>
from homeassistant.helpers.restore_state import async_restore_state
17-04-24 21:03:34 ERROR (MainThread) [homeassistant.loader] Unable to find component light
17-04-24 21:03:34 ERROR (MainThread) [homeassistant.setup] Setup failed for light: Component not found.
