Enabling debug for bluetooth integration, I can see this in the log:
2025-09-05 18:29:03.760 DEBUG (MainThread) [habluetooth.base_scanner] hci0 (08:BF:B8:53:92:73): Scanner watchdog time_since_last_detection: 30.004899978637695
2025-09-05 18:29:33.762 DEBUG (MainThread) [habluetooth.base_scanner] hci0 (08:BF:B8:53:92:73): Scanner watchdog time_since_last_detection: 60.00578689575195
2025-09-05 18:30:03.764 DEBUG (MainThread) [habluetooth.base_scanner] hci0 (08:BF:B8:53:92:73): Scanner watchdog time_since_last_detection: 90.00666046142578
2025-09-05 18:30:03.765 DEBUG (MainThread) [habluetooth.scanner] hci0 (08:BF:B8:53:92:73): Bluetooth scanner has gone quiet for 90.00666046142578s, restarting
2025-09-05 18:30:03.765 DEBUG (MainThread) [habluetooth.scanner] hci0 (08:BF:B8:53:92:73): Stopping bluetooth discovery
2025-09-05 18:30:03.786 DEBUG (MainThread) [habluetooth.scanner] hci0 (08:BF:B8:53:92:73): adapter stopped responding; executing reset
2025-09-05 18:30:03.900 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Attempting to recover bluetooth adapter hci0 with mac address 08:BF:B8:53:92:73 (gone_silent=True)
2025-09-05 18:30:03.900 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Attempting to power cycle bluetooth adapter hci0 [08:BF:B8:53:92:73]
2025-09-05 18:30:03.906 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Found adapters from hci: {0: {'dev_id': 0, 'name': 'hci0', 'bdaddr': '08:BF:B8:53:92:73', 'flags': 5, 'type': 1, 'features': <ifaddr._shared.c_ubyte_Array_8 object at 0x7f4af97f9750>, 'pkt_type': 52472, 'link_policy': 15, 'link_mode': 32768, 'acl_mtu': 1021, 'acl_pkts': 6, 'sco_mtu': 255, 'sco_pkts': 12, 'stat': <bluetooth_adapters.systems.linux_hci.hci_dev_stats object at 0x7f4af97f9250>}}
2025-09-05 18:30:03.907 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Found adapter 08:BF:B8:53:92:73 by mac in hci device as 0
2025-09-05 18:30:03.907 DEBUG (MainThread) [bluetooth_auto_recovery.recover] _get_adapter: hci0 [08:BF:B8:53:92:73] (hci_name=hci0) (mac=08:BF:B8:53:92:73) (idx=0)
2025-09-05 18:30:03.910 DEBUG (SyncWorker_3) [bluetooth_auto_recovery.recover] rfkill at /dev/rfkill is not accessible, cannot check bluetooth adapter hci0 [08:BF:B8:53:92:73] (0): [Errno 2] No such file or directory: '/dev/rfkill'
2025-09-05 18:30:03.912 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Could not determine rfkill_idx of hci0 [08:BF:B8:53:92:73] (0): RFKillInfo(soft_block=None, hard_block=None, idx=None)
2025-09-05 18:30:03.913 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Attempting to power cycle bluetooth adapter hci0 [08:BF:B8:53:92:73] (0)
2025-09-05 18:30:03.913 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding cmd_code as type CmdCode
2025-09-05 18:30:03.914 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding controller_idx as type Controller
2025-09-05 18:30:03.915 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding param_len as type ParamLen
2025-09-05 18:30:03.933 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding event_code as type EvtCode
2025-09-05 18:30:03.934 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding controller_idx as type Controller
2025-09-05 18:30:03.935 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding param_len as type ParamLen
2025-09-05 18:30:03.935 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding command_opcode as type CmdCode
2025-09-05 18:30:03.936 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding status as type Status
2025-09-05 18:30:03.936 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding address as type Address
2025-09-05 18:30:03.937 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding bluetooth_version as type IntUL
2025-09-05 18:30:03.937 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding manufacturer as type IntUL
2025-09-05 18:30:03.937 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding supported_settings as type IntUL
2025-09-05 18:30:03.938 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding current_settings as type CurrentSettings
2025-09-05 18:30:03.938 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding class_of_device as type IntUL
2025-09-05 18:30:03.939 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding name as type Name
2025-09-05 18:30:03.939 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding short_name as type IntUL
2025-09-05 18:30:03.939 DEBUG (MainThread) [btsocket.btmgmt_protocol] Socket Read: <event_code=CommandCompleteEvent, controller_idx=0, param_len=283> <command_opcode=ReadControllerInformation, status=Success> <address=08:BF:B8:53:92:73, bluetooth_version=10, manufacturer=93, supported_settings=245759, current_settings={Powered: True, Connectable: False, FastConnectable: False, Discoverable: False, Bondable: False, LinkLevelSecurity: False, SecureSimplePairing: True, BREDR: True, HighSpeed: False, LowEnergy: True, Advertising: False, SecureConnections: True, DebugKeys: False, Privacy: False, ControllerConfiguration: False, StaticAddress: False, PHYConfiguration: False, WidebandSpeech: False}, class_of_device=260, name=b'lmhome', short_name=0>
2025-09-05 18:30:03.940 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Current power state of bluetooth adapter is ON.
2025-09-05 18:30:03.941 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding powered as type IntUL
2025-09-05 18:30:03.941 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding cmd_code as type CmdCode
2025-09-05 18:30:03.941 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding controller_idx as type Controller
2025-09-05 18:30:03.942 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding param_len as type ParamLen
2025-09-05 18:30:03.943 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding event_code as type EvtCode
2025-09-05 18:30:03.944 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding controller_idx as type Controller
2025-09-05 18:30:03.944 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding param_len as type ParamLen
2025-09-05 18:30:03.944 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding command_opcode as type CmdCode
2025-09-05 18:30:03.945 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding status as type Status
2025-09-05 18:30:03.945 DEBUG (MainThread) [btsocket.btmgmt_protocol] Socket read <event_code=CommandStatusEvent, controller_idx=0, param_len=3> <command_opcode=SetPowered, status=PermissionDenied>
2025-09-05 18:30:03.950 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding event_code as type EvtCode
2025-09-05 18:30:03.951 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding controller_idx as type Controller
2025-09-05 18:30:03.952 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding param_len as type ParamLen
2025-09-05 18:30:03.953 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding command_opcode as type CmdCode
2025-09-05 18:30:03.955 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding status as type Status
2025-09-05 18:30:03.956 DEBUG (MainThread) [btsocket.btmgmt_protocol] Socket read <event_code=CommandStatusEvent, controller_idx=0, param_len=3> <command_opcode=SetPowered, status=PermissionDenied>
2025-09-05 18:30:03.958 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding event_code as type EvtCode
2025-09-05 18:30:03.959 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding controller_idx as type Controller
2025-09-05 18:30:03.959 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding param_len as type ParamLen
2025-09-05 18:30:03.960 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding command_opcode as type CmdCode
2025-09-05 18:30:03.961 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding status as type Status
2025-09-05 18:30:03.963 DEBUG (MainThread) [btsocket.btmgmt_protocol] Socket read <event_code=CommandStatusEvent, controller_idx=0, param_len=3> <command_opcode=SetPowered, status=PermissionDenied>
2025-09-05 18:30:03.966 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding event_code as type EvtCode
2025-09-05 18:30:03.967 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding controller_idx as type Controller
2025-09-05 18:30:03.967 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding param_len as type ParamLen
2025-09-05 18:30:03.968 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding command_opcode as type CmdCode
2025-09-05 18:30:03.968 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding status as type Status
2025-09-05 18:30:03.969 DEBUG (MainThread) [btsocket.btmgmt_protocol] Socket read <event_code=CommandStatusEvent, controller_idx=0, param_len=3> <command_opcode=SetPowered, status=PermissionDenied>
2025-09-05 18:30:03.970 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding event_code as type EvtCode
2025-09-05 18:30:03.971 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding controller_idx as type Controller
2025-09-05 18:30:03.971 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding param_len as type ParamLen
2025-09-05 18:30:03.972 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding command_opcode as type CmdCode
2025-09-05 18:30:03.972 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding status as type Status
2025-09-05 18:30:03.972 DEBUG (MainThread) [btsocket.btmgmt_protocol] Socket read <event_code=CommandStatusEvent, controller_idx=0, param_len=3> <command_opcode=SetPowered, status=PermissionDenied>
2025-09-05 18:30:03.976 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding event_code as type EvtCode
2025-09-05 18:30:03.977 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding controller_idx as type Controller
2025-09-05 18:30:03.977 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding param_len as type ParamLen
2025-09-05 18:30:03.977 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding command_opcode as type CmdCode
2025-09-05 18:30:03.978 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding status as type Status
2025-09-05 18:30:03.978 DEBUG (MainThread) [btsocket.btmgmt_protocol] Socket read <event_code=CommandStatusEvent, controller_idx=0, param_len=3> <command_opcode=SetPowered, status=PermissionDenied>
2025-09-05 18:30:08.952 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding event_code as type EvtCode
2025-09-05 18:30:08.953 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding controller_idx as type Controller
2025-09-05 18:30:08.953 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding param_len as type ParamLen
2025-09-05 18:30:08.954 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding command_opcode as type CmdCode
2025-09-05 18:30:08.954 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding status as type Status
2025-09-05 18:30:08.954 DEBUG (MainThread) [btsocket.btmgmt_protocol] Socket read <event_code=CommandStatusEvent, controller_idx=0, param_len=3> <command_opcode=SetPowered, status=PermissionDenied>
2025-09-05 18:30:08.956 WARNING (MainThread) [bluetooth_auto_recovery.recover] Could not reset the power state of the Bluetooth adapter hci0 [08:BF:B8:53:92:73] (0) due to timeout after 5 seconds
2025-09-05 18:30:08.972 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Bouncing Bluetooth adapter hci0
2025-09-05 18:30:08.972 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Setting hci0 down
2025-09-05 18:30:08.976 WARNING (MainThread) [bluetooth_auto_recovery.recover] Could not cycle the Bluetooth adapter hci0 [08:BF:B8:53:92:73] (0): [Errno 1] Operation not permitted
2025-09-05 18:30:08.977 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding powered as type IntUL
2025-09-05 18:30:08.978 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding cmd_code as type CmdCode
2025-09-05 18:30:08.978 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding controller_idx as type Controller
2025-09-05 18:30:08.979 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding param_len as type ParamLen
2025-09-05 18:30:08.979 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding event_code as type EvtCode
2025-09-05 18:30:08.980 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding controller_idx as type Controller
2025-09-05 18:30:08.980 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding param_len as type ParamLen
2025-09-05 18:30:08.981 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding command_opcode as type CmdCode
2025-09-05 18:30:08.981 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding status as type Status
2025-09-05 18:30:08.981 DEBUG (MainThread) [btsocket.btmgmt_protocol] Socket read <event_code=CommandStatusEvent, controller_idx=0, param_len=3> <command_opcode=SetPowered, status=PermissionDenied>
2025-09-05 18:30:08.988 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth management socket connection lost: [Errno 22] Invalid argument
2025-09-05 18:30:13.981 WARNING (MainThread) [bluetooth_auto_recovery.recover] Could not reset the power state of the Bluetooth adapter hci0 [08:BF:B8:53:92:73] (0) due to timeout after 5 seconds
2025-09-05 18:30:13.982 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Executing USB reset for Bluetooth adapter hci0
2025-09-05 18:30:13.990 DEBUG (MainThread) [bluetooth_auto_recovery.recover] hci0 not found while attempting USB reset: [Errno 2] No such file or directory: '/dev/bus/usb/002/002'
2025-09-05 18:30:13.991 WARNING (MainThread) [bluetooth_auto_recovery.recover] Closing Bluetooth adapter hci0 [08:BF:B8:53:92:73] failed: [Errno 9] Bad file descriptor
2025-09-05 18:30:13.991 DEBUG (MainThread) [habluetooth.scanner] hci0 (08:BF:B8:53:92:73): adapter reset result: False
2025-09-05 18:30:13.992 DEBUG (MainThread) [habluetooth.scanner] Initializing bluetooth scanner with {'scanning_mode': 'active', 'adapter': 'hci0'}
2025-09-05 18:30:13.992 DEBUG (MainThread) [habluetooth.scanner] hci0 (08:BF:B8:53:92:73): Force stopping bluetooth discovery
2025-09-05 18:30:13.993 DEBUG (MainThread) [habluetooth.scanner] hci0 (08:BF:B8:53:92:73): Starting bluetooth discovery attempt: (1/4)
2025-09-05 18:30:14.009 DEBUG (MainThread) [habluetooth.scanner] hci0 (08:BF:B8:53:92:73): Success while starting bluetooth; attempt: (1/4)
2025-09-05 18:30:14.010 DEBUG (MainThread) [bleak_retry_connector] Restored 3 discoveries for hci0
in the cut out part (the ellipsis) the same rows just repeat again and again.
Is it a bug of the newer version?
