The screenshot in your first post shows that you moved the configuration of all of your sensors under the command_line: key.
You're only supposed to move the configuration of Command Line sensors under the command_line: key (you also moved Wake On Lan, Template, etc). In addition, the configuration format for Command Line sensors has changed slightly so you can't simply copy the old configuration format and paste it under the command_line: key.
