Hello, all.
I tried to reproduce reverse SSH tunnel from topic Howto: Create a reverse SSH tunnel, with easy HTTPS at the other end, but I stuck on
Error: Invalid client id
I have HA instance of Home Assistant Operating System VMWare image, with Duck DNS add-on and it works very well on http s://sozid.duckdns.org:8123/ .
HA VM works on home server, that behind router. Router has “white” IP, not NAT. 8123 port of external IP mapped to 192.168.0.102:8123 with port forwarding on router.
I also have Terminal & SSH add-on installed with config
authorized_keys: []
password: qqqqqqq
apks:
- autossh
server:
tcp_forwarding: false
packages:
- autossh
username: root
Also I have external server with NGINX installed, that proxy request with config
location / {
proxy_pass http s://localhost:8887;
When I log into HA instance by SSH and run
/usr/bin/ssh -N -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null -o PubkeyAuthentication=yes -o PasswordAuthentication=no -i /root/config/id_rsa -R 8887:localhost:8123 [email protected]
It starts:
Warning: Permanently added ‘176.32.32.98’ (ED25519) to the list of known hosts.
When I try to open http ://176.32.32.98/
I see nginx error
# 502 Bad Gateway
and error in HA SSH console:
connect_to localhost port 8123: failed.
OKay, I tried to change SSH start to
/usr/bin/ssh -N -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null -o PubkeyAuthentication=yes -o PasswordAuthentication=no -i /root/config/id_rsa -R 8887:192.168.0.102:8123 [email protected]
Where 192.168.0.102 is local IP of my HA (http s://192.168.0.102:8123/lovelace/default_view works very well, I also connecting to 192.168.0.102 by SSH to start command for SSH tunnel).
After that http ://176.32.32.98/ starts to open, but redirects to
http ://176.32.32.98/auth/authorize?response_type=code&redirect_uri=http %3A%2F%2F176.32.32.98%2F%3Fauth_callback%3D1&client_id=http %3A%2F%2F176.32.32.98%2F&state=eyJoYXNzVXJsIjoiaHR0cDovLzE3Ni4zMi4zMi45OCIsImNsaWVudElkIjoiaHR0cDovLzE3Ni4zMi4zMi45OC8ifQ%3D%3D
It’s page
You’re about to give http ://176.32.32.98/ access to your Home Assistant instance.
Logging in with Home Assistant Local.
START OVER
So, http s://sozid.duckdns.org:8123/ and http s://192.168.0.102:8123/ work very well, but http ://176.32.32.98/ with SSH tunnel shows error.
Tell me please, how to fix that error with http ://176.32.32.98/?
