Error with urllib3
I am having trouble upgrading from 0.57.3 to 0.60. I get the following error:
File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 594, in urlopen
    chunked=chunked)
I see this same error occurring in other posts that have no resolution:
These three posts, along with my issue all seem to be about urllib3
My installation is on Raspbian Stretch. I have done a update so all packages should be as new as they can be.
My installation process, as user homeassistant is this:
14:10:08 rpizero3 homeassistant:~> source /srv/homeassistant/bin/activate
(homeassistant) 14:11:43 rpizero3 homeassistant:~> pip3 install --upgrade homeassistant
This is the full traceback. The last line is the root error:
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 594, in urlopen
    chunked=chunked)
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 391, in _make_request
    six.raise_from(e, None)
  File "<string>", line 2, in raise_from
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 387, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/lib/python3.5/http/client.py", line 1198, in getresponse
    response.begin()
  File "/usr/lib/python3.5/http/client.py", line 297, in begin
    version, status, reason = self._read_status()
  File "/usr/lib/python3.5/http/client.py", line 266, in _read_status
    raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
There are two tracebacks. The second traceback is from urllib3/uti/retry.py. I have been trying to figure out the error in that code, but I can’t find one.
The error is coming from line 337 in urllib3-1.22 and line 315 in urllib3-1.19.1.
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/commands/install.py", line 353, in run
    wb.build(autobuilding=True)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/wheel.py", line 749, in build
    self.requirement_set.prepare_files(self.finder)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py", line 380, in prepare_files
    ignore_dependencies=self.ignore_dependencies))
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py", line 487, in _prepare_file
    req_to_install, finder)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py", line 428, in _check_skip_installed
    req_to_install, upgrade_allowed)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 465, in find_requirement
    all_candidates = self.find_all_candidates(req.name)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 423, in find_all_candidates
    for page in self._get_pages(url_locations, project_name):
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 568, in _get_pages
    page = self._get_page(location)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 683, in _get_page
    return HTMLPage.get_page(link, session=self.session)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 792, in get_page
    "Cache-Control": "max-age=600",
  File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 501, in get
    return self.request('GET', url, **kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/download.py", line 386, in request
    return super(PipSession, self).request(method, url, *args, **kwargs)
  File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 488, in request
    resp = self.send(prep, **send_kwargs)
  File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 609, in send
    r = adapter.send(request, **kwargs)
  File "/srv/homeassistant/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 47, in send
    resp = super(CacheControlAdapter, self).send(request, **kw)
  File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py", line 423, in send
    timeout=timeout
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 639, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/util/retry.py", line 337, in increment
    total -= 1
TypeError: unsupported operand type(s) for -=: 'Retry' and 'int'
not sure if related, but I’ve just upgraded to 0.60 and I too have loads of errors with urllib3:
2017-12-19 20:49:14 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.5/dist-packages/urllib3/connection.py", line 141, in _new_conn
    (self.host, self.port), self.timeout, **extra_kw)
  File "/usr/local/lib/python3.5/dist-packages/urllib3/util/connection.py", line 83, in create_connection
    raise err
  File "/usr/local/lib/python3.5/dist-packages/urllib3/util/connection.py", line 73, in create_connection
    sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
  File "/usr/local/lib/python3.5/dist-packages/urllib3/connectionpool.py", line 601, in urlopen
    chunked=chunked)
  File "/usr/local/lib/python3.5/dist-packages/urllib3/connectionpool.py", line 357, in _make_request
    conn.request(method, url, **httplib_request_kw)
  File "/usr/lib/python3.5/http/client.py", line 1106, in request
    self._send_request(method, url, body, headers)
  File "/usr/lib/python3.5/http/client.py", line 1151, in _send_request
    self.endheaders(body)
  File "/usr/lib/python3.5/http/client.py", line 1102, in endheaders
    self._send_output(message_body)
  File "/usr/lib/python3.5/http/client.py", line 934, in _send_output
    self.send(msg)
  File "/usr/lib/python3.5/http/client.py", line 877, in send
    self.connect()
  File "/usr/local/lib/python3.5/dist-packages/urllib3/connection.py", line 166, in connect
    conn = self._new_conn()
  File "/usr/local/lib/python3.5/dist-packages/urllib3/connection.py", line 150, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f50033e6780>: Failed to establish a new connection: [Errno 111] Connection refused
  File "/usr/local/lib/python3.5/dist-packages/requests/adapters.py", line 440, in send
    timeout=timeout
  File "/usr/local/lib/python3.5/dist-packages/urllib3/connectionpool.py", line 639, in urlopen
  File "/usr/local/lib/python3.5/dist-packages/urllib3/util/retry.py", line 388, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.24', port=8083): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f50033e6780>: Failed to establish a new connection: [Errno 111] Connection refused',))
  File "/usr/local/lib/python3.5/dist-packages/aiohttp/web_protocol.py", line 410, in start
    resp = yield from self._request_handler(request)
  File "/usr/local/lib/python3.5/dist-packages/aiohttp/web.py", line 325, in _handle
    resp = yield from handler(request)
  File "/usr/local/lib/python3.5/dist-packages/aiohttp/web_middlewares.py", line 93, in impl
    return (yield from handler(request))
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/http/ban.py", line 58, in ban_middleware
  File "/usr/lib/python3.5/asyncio/coroutines.py", line 209, in coro
    res = yield from res
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/http/__init__.py", line 430, in handle
    result = yield from result
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/camera/__init__.py", line 387, in get
    response = yield from self.handle(request, camera)
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/camera/__init__.py", line 407, in handle
    image = yield from camera.async_camera_image()
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/camera/mjpeg.py", line 92, in async_camera_image
    self.camera_image)
  File "/usr/lib/python3.5/asyncio/futures.py", line 361, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 296, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 274, in result
    raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/camera/mjpeg.py", line 120, in camera_image
    req = requests.get(self._mjpeg_url, stream=True, timeout=10)
  File "/usr/local/lib/python3.5/dist-packages/requests/api.py", line 72, in get
    return request('get', url, params=params, **kwargs)
  File "/usr/local/lib/python3.5/dist-packages/requests/api.py", line 58, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.5/dist-packages/requests/sessions.py", line 508, in request
  File "/usr/local/lib/python3.5/dist-packages/requests/sessions.py", line 618, in send
  File "/usr/local/lib/python3.5/dist-packages/requests/adapters.py", line 508, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.24', port=8083): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f50033e6780>: Failed to establish a new connection: [Errno 111] Connection refused',))
    raise err
    sock.connect(sa)
    chunked=chunked)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f5003da0a58>: Failed to establish a new connection: [Errno 111] Connection refused
and so on.
192.168.0.24:8081 to 8083 are port for motion
The cameras are being streamed correctly in the front end so not sure what the issue is…
just noticed this on Generic MJPEG IP Camera Doc:
There is a known issue in urllib3 that you will get error messages in your logs like [StartBoundaryNotFoundDefect(), MultipartInvariantViolationDefect()], unparsed data: ‘’ but the component still works fine. You can ignore the messages.
In my case the error during the upgrade to 0.60.0 which caused the upgrade to terminate. I had to update all the dependencies manually which was very time consuming.
Before giving up and resorting to the manual upgrades of the dependencies, I tried downgrading to urllib3 1.18.1 (2016-10-27) and the problem still existed. Previous to 0.60.0, homeassistant was using urllib3 1.19.1 (2016-11-16). That means that during the upgrade process, 1.19.1 was in effect. Now, as of 0.60.0 homeassistant is using urllib3 1.22 (2017-07-20).
BTW, removing urllib3 breaks pip. If you remove urllib3 in an effort to use a different version, make sure you some method other than pip to install it.
