Error with Xiaomi Miio on 0.62.1 - Vacuum
After upgrading to 0.62.1 Im getting the following errors in the logs. I have other devices such as temperature sensors and switches from the xiaomi gateway which are fine, but it seems like only the vacuum piece isn’t working. Has anyone come across these before?
2018-02-10 11:56:41 ERROR (MainThread) [homeassistant.components.vacuum] Error while setting up platform xiaomi_miio
File “/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py”, line 189, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File “/usr/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 245, in result
raise self._exception
File “/usr/lib/python3.6/asyncio/tasks.py”, line 180, in _step
result = coro.send(None)
File “/usr/lib/python3.6/asyncio/coroutines.py”, line 210, in coro
res = func(*args, **kw)
File “/usr/lib/python3.6/site-packages/homeassistant/components/vacuum/xiaomi_miio.py”, line 90, in async_setup_platform
from miio import Vacuum
File “/usr/lib/python3.6/site-packages/miio/init.py”, line 2, in
from miio.protocol import Message, Utils
File “/usr/lib/python3.6/site-packages/miio/protocol.py”, line 179, in
Const(0x2131, Int16ub),
File “/usr/lib/python3.6/site-packages/construct/core.py”, line 1894, in init
super(Const, self).init(subcon)
File “/usr/lib/python3.6/site-packages/construct/core.py”, line 291, in init
raise TypeError(“subcon should be a Construct field”)
TypeError: subcon should be a Construct field
Yes. This is a known issue (I have it too) with 62 and 62.1.
I think DanielHIversen has fixed it via Xiaomi Py and it should work in upcomming 63.
Upgraded to 0.63 and this doesn’t appear resolved. Is there a manual update to get this working again?
