Error with ZHA Integration on Home Assistant Yellow
I’m trying to add Zigbee Home Automation on my Home Assistant Yellow running Home Assistant OS core-2025.1.0, and I’m getting this error when trying to add Zigbee Home Automation
Error
Config flow could not be loaded: 500 Internal Server Error Server got itself in trouble
And the log I got is:
Logger: aiohttp.server
Source: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:451
First occurred: 2:24:18 AM (3 occurrences)
Last logged: 2:34:47 AM
Error handling request
  File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 113, in list_serial_ports
    yellow_radio = next(p for p in ports if p.device == "/dev/ttyAMA1")
StopIteration
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 480, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 210, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 172, in post
    return await self._post_impl(request, data)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 179, in _post_impl
    return await super()._post_impl(request, data)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 84, in _post_impl
    result = await self._flow_mgr.async_init(
    ...<2 lines>...
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1315, in async_init
    flow, result = await self._async_init(flow_id, handler, context, data)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1350, in _async_init
    result = await self._async_handle_step(flow, flow.init_step, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 491, in _async_handle_step
    result: _FlowResultT = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 546, in async_step_user
    return await self.async_step_choose_serial_port(user_input)
  File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 188, in async_step_choose_serial_port
    ports = await list_serial_ports(self.hass)
RuntimeError: coroutine raised StopIteration
Any idea how to fix this? Appreciate it!
I got same error when trying to “Add integration” for “Zigbee home automation”. I have no idea why this does not work right out-of-the-box…
Any solution???
Home Assistant Yellow with CM5 and NVMe SSD.
log says this:
File “/usr/src/homeassistant/homeassistant/components/zha/config_flow.py”, line 188, in async_step_choose_serial_port
I’ve raised an issue as my radio worked until I removed the interface to try to reconfigure it, and have created this situation. Restoring a backup restores functionality so it’s definitely a software funny.
This has been fixed in 2025.2.1 for CM5-based Home Assistant Yellows!
