Hello. I recently started to get an error from my Companion App running on a Pixel 7 Pro. The error does not occur when I first open the app, but occurs when the phone has been sitting for 5+ mins. When I wake the phone and re-open the Companion App, which was running in the background, I get the following error:
“failed to call service system_log/write. unknown error”
I believe this has something to do with updating sensor, as I use this device to track my location via BLE. I’ve noticed that while the phone “sleeping”, the sensors aren’t updating. Once I get this error, the sensor will update, but only if I’m active on the phone… sensors stop updating it the phone is asleep.
I did check the logs and I didn’t see anything that stood out to me, but obviously I’m missing something.
This error/problem, does not occur on any other devices running, including other phones running the Companion App sending sensor information.
Hoping to get some guidance on how to fix this, as I use location data from this phone to control many things.
Thank you.
David
