Problem: Integration Z-Wave JS displays Error “Retrying setup: Z-Wave JS Server version is incompatible: 1.15.0 a version is required that supports at least api schema 17”
Problem first occured when updating Home Assistant OS to 2022.5.x. Few other components have also been. updated. There should have been taken a backup for each update, but restore to any incremental backups fails.
Prior to the last updates system was working normally.
Zigbee integration works normally.
Installation type: Home Assistant OS
Home Assistant version: core-2022.6.0
Home Assistant log:
Logger: homeassistant.config_entries
Source: config_entries.py:370
First occurred: 9:23:02 PM (6 occurrences)
Last logged: 10:44:16 PM
Config entry 'Z-Wave JS' for zwave_js integration not ready yet: Z-Wave JS Server version is incompatible: 1.15.0 a version is required that supports at least api schema 17; Retrying in background
Config entry 'SAGEM F@ST3686' for upnp integration not ready yet: Error connecting to device at location: http://192.168.0.1:80/RootDevice.xml, err: ('[Errno 104] Connection reset by peer', None); Retrying in background
Z-Wave JS version 0.1.60
Z-Wave JS Log:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/config.sh
[22:28:33] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
[22:28:34] INFO: Virtual Machine not detected, enabling soft-reset
cont-init: info: /etc/cont-init.d/config.sh exited 0
cont-init: info: running /etc/cont-init.d/structure.sh
cont-init: info: /etc/cont-init.d/structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun zwave_js (no readiness notification)
s6-rc: info: service legacy-services successfully started
[22:28:36] INFO: Successfully send discovery information to Home Assistant.
2022-06-01T20:28:39.716Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
2022-06-01T20:28:39.726Z DRIVER version 9.3.0
2022-06-01T20:28:39.727Z DRIVER
Nodes in Z-Wave JS work normally.
Please help.
