Error "zh:deconz:driver: no free slots. Delay sending of APS Request"
Folks,
This error started to appear a couple of days ago. It randomly shows up after HA restart and I need to repeat it until it goes away. Eventually it does and the Conbee II stick works again. Any idea what I can do to fix it?
Error message repeating in the logs: zh:deconz:driver: no free slots. Delay sending of APS Request
Pattern discovered:
restart of the HA or the RPI causes the error
physical shutdown, power off, power on & restart: avoids the error
Any ideas?
same issue here. I do a shutdown and start of the computer where is the HA running… and have this problem.
apparently, this was solved with a restart only to HA system and it seems working normal again…
It seems the problem is with the deconz USB stick – I just replaced it and so far (keeping fingers crossed) did not have any issues anymore…
I have the same problem now.
