I have newly setup my z-wave network on home assistant.
In individual cases all runs ok - however, as soon as there is a little bit more traffic (triggering actions multiple times within a minute) I receive regularly errors and the z-wave devices will not work anymore.
Error in home assistant log is:
Z-Wave error 1405: The node failed to decode the message (ZW1405)
I am running
a aeotec z-stick 7
Home Assistant OS 8.1 / Home Assistant Core 2022.5.5
Fibaro roller shutter 3 FGR-223
Any idea is highly appreciated. I am otherwise thinking about throwing all my fibaros out switching to Shelly.
I just got this for first time today when trying to adjust the dimmer on a Zooz 72 light.
Logger: homeassistant.components.websocket_api.http.connection
Source: components/zwave_js/light.py:354
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 7:55:27 PM (1 occurrences)
Last logged: 7:55:27 PM
[547157835008] Z-Wave error 1405: The node failed to decode the message. (ZW1405)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 193, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1704, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1741, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 680, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 964, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 717, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 553, in async_handle_light_on_service
await light.async_turn_on(**filter_turn_on_params(light, params))
File "/usr/src/homeassistant/homeassistant/components/zwave_js/light.py", line 293, in async_turn_on
await self._async_set_brightness(kwargs.get(ATTR_BRIGHTNESS), transition)
File "/usr/src/homeassistant/homeassistant/components/zwave_js/light.py", line 354, in _async_set_brightness
await self.info.node.async_set_value(
File "/usr/local/lib/python3.9/site-packages/zwave_js_server/model/node/__init__.py", line 446, in async_set_value
result = await self.async_send_command(
File "/usr/local/lib/python3.9/site-packages/zwave_js_server/model/node/__init__.py", line 403, in async_send_command
result = await self.client.async_send_command(message, **kwargs)
File "/usr/local/lib/python3.9/site-packages/zwave_js_server/client.py", line 103, in async_send_command
return await future
zwave_js_server.exceptions.FailedZWaveCommand: Z-Wave error 1405: The node failed to decode the message. (ZW1405)
I suspect something changed with zwavejs and core upgrade recently?
Unfortunately I’m getting an error when interviewing. I submitted a bug request. Nothing changed with my hardware prior to upgrades. Guessing something broke?
I have the same issue with Fibaro roller shutter 3 FGR-223 and ZST39 that sometimes get this error:
Unable to set value 20-38-2-targetValue : zwave_error: Z-Wave error 1405 - The node failed to decode the message. (ZW1405) or
Unable to set value 31-38-2-targetValue : zwave_error: Z-Wave error 202 - Failed to send the command after 5 attempts (ZW0202)
I think it’s a problem with Fibaro modules but when I used that same modules with Fibaro HC3 it works perfect. One lucky that this problem just pops up like 1 time per month because I’ll need go back to Fibaro .
