Errors after Home Assistant upgrade
Ever since I upgraded to 0.22 (now on 0.22.1) the z-wave adapter has not been showing up in home assistant. The log shows the following error:
16-06-27 23:28:02 homeassistant.components.zwave: You are missing required dependency Python Open Z-Wave. Please follow instructions at: https://home-assistant.io/components/zwave/
16-06-27 23:28:02 homeassistant.bootstrap: component zwave failed to initialize
I’ve gone back and redone these steps several times:
but still the same error.
I can access the Aeotec ZW090 Z-Stick Gen5 from the OpenZWave Control Panel so I know that aspect works. But home assistant wont load it. I do not run the control panel when zwave is running so the /dev/ttyACM0 isnt being occupied when home assistant is trying to load it.
I have this same issue as well… !!! :frowning:
I forgot how i got around it but i saw that homeassistant was pointing to the wrong library. So i had to create a soft link in the library folder.
